Help - How can I translate 3.3V(SpartanII) to a 15V(CMOS)
jonatan
Member level 1
Does Anyone know how to translate the 3.3V output from SPARTAN IIE
(LVTTL) up to a 15V CMOS level, with current buffer together.
Is there an IC to do this work, such as 74AHCT24 (standard 5V CMOS buffer - 3.3 --> 5V), or circuit to provide this level shifting?
Thanks in advance
Re: Help - How can I translate 3.3V(SpartanII) to a 15V(CMOS
is propagation delay of interest?? (building a circuit with multiple voltage shifters) ... or simply build an open-drain styled outputstage using e. g. FETs that is driven by your Spartan II)
Can you give us more information about your application??
regards,
Maddin
you can try a 74HCT07 buffer. the ic has a open collector output, so you can pull it up to 15V.
regards
revolt
