missbirdie
Member level 1
parallel to serial vhdl
Hello
I have a question about the following VHDL code to convert from parallel to serial:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity PAR2SER is
Port ( DIN : in STD_LOGIC;
MODE : in STD_LOGIC;
CLK : in STD_LOGIC;
RESET : in STD_LOGIC;
SDOUT : out STD_LOGIC);
end PAR2SER;
-- purpose: Implement main architecture of PAR2SER
architecture BEHAVIOR of PAR2SER is
signal IDATA : std_logic_vector(7 downto 0); -- internal data
begin -- BEHAVIOR
-- purpose: Main process
process (CLK, RESET)
begin -- process
-- activities triggered by asynchronous reset (active high)
if RESET = ’1’ then
SDOUT <= ’0’;
IDATA <= "00000000";
-- activities triggered by rising edge of clock
elsif CLK’event and CLK = ’1’ then
case MODE is
when "00" => -- no operation
null;
when "01" => -- load operation
IDATA <= DIN;
when "10" => -- shift left
SDOUT <= IDATA(7);
for mloop in 6 downto 0 loop
IDATA(mloop+1) <= IDATA(mloop);
end loop; -- mloop
when others => -- no operation otherwise
null;
end case;
end if;
end process;
end BEHAVIOR;
I may sound silly but what's the mode pin for ??
Hello
library IEEE;
entity PAR2SER is
CLK : in STD_LOGIC;
end PAR2SER;
begin -- BEHAVIOR
begin -- process
if RESET = ’1’ then
SDOUT <= ’0’;
case MODE is
null;
IDATA <= DIN;
SDOUT <= IDATA(7);
end loop; -- mloop
null;
end case;
end if;
end process;
end BEHAVIOR;
