Advark
Member level 3
- Joined
- Feb 22, 2008
- Messages
- 66
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- POA, Brazil-RS
- Activity points
- 1,684
solid state power amplifier
Hello.
I need help or some orientation with the simulation of a PA, I have design the input and output matching stages, but a I've found some difficulties when i'm going to simulate it.
First at all the characterisitics of the PA are:
Output power: 1kW:
VCC supply: 300V:
Frequency Operation: 50Mhz
Topology: Push Pull, handling two parallel transistor per 180° outphase.
Transistor: Vertical DMOS, ARF446-447 of MICROSEMI.
I'm going to use the AWR Microwave Office for the simulation.
The problems that i found are:
I don't know how to simulate the transformer, 4:1 and 1:4 transformer.
I only found the spice model of the transistor and i don't know how to use it with the AWR, if make a netlist or make and schematic.
and how to obtain the zin zout of the transistor for a better simulation of the input and output matching stages.
Waiting for your help
David.
Hello.
Output power: 1kW:
VCC supply: 300V:
David.
