Cesar0182
Member level 5
Greetings ... comment that I am trying to simulate a project made in Vivado 2017.3 and the simulator I am using is Modelsim SE 64 10.5, the error I have is the one shown in the attached image.
Initially the simulation worked correctly, but to this project I added a new IP created in ISE 14.5, which initially gave me the error:
Library "xilinxcorelib" not found
therefore I decided to update it to the version of Vivado 2017.3, but even so I still had the same error, later I wanted to verify if the same thing happened in the Vivado simulator, but incredibly it worked without problems there. But still I ended up removing the IP from the project. And from there that my project began to show me that error that I share and so far I have not been able to find a solution to this.
Could someone help me with this please.
