paardenvlees
I build a circuit wit a drive buffer. When i make use of the logictoggle input from proteus the buffer(74HC365) is working correctly and when i replace them by just voltage sources and toggle the voltage source high low, it is not working anymore?
I have an output of 3.3V/0.0V from a comperator circuit and i want to use that as input to the OE. on the inputs at A1 there is also a 3.3V input.
Is this not working in proteus or what am i doing wrong?
