Overvoltage Protection
zuirgham
Junior Member level 3
Vin = 9.2V - 9.8V. For the circuit mentioned in the figure, if Input Voltage crosses 10V , Zener gets activated.
For the given circuit, when zener is activated, will more current flow through the base of PNP and cause any trouble to the PNP transistor ? Or the circuit would do fine ?
Provided you use the specified transistor it should be fine, its internal base resistor will limit the current to a safe level.
You have no DC supply connection to the transistor emitter, so it won't work.
Look again, the circuit is fine.
If you don't have one of those "digital transistors" with built-in base resistors, you need to add an external base resistor.
