dpaul
I am using Microsemi Libero SoC 12.3 tool suite. With it comes ModelSim ME Pro 2019.2.
But I cannot run overnight simulations with this ModelSim ver as it loses memory @0.1MB/sec. It is the 32bit version and after >4GB utilization, ModelSim crashes.
Problem has been reported to Microsemi.
Now I also have a ModelSim DE-64 10.5 license and my intention is to use this instead of the shipped ModelSim version.
I have read the Microsemi docu modelsim_se_pe_libero_soc_ug.pdf but it speaks only about using ModelSim SE/PE or QuestaSim. I am not sure if I can use the ModelSim-DE version seamlessly.
Nevertheless I have been successful to launch the ModelSim DE version from Libero.
I have used the tool generated run.do file and have manually run the vlib, vmap and vlog/vcom commands inside the required directory (after deleting the previously generated ones). But I get errors during the DO file compilation. Some block designs and FIFOs throws errors. I never had these errors when the default ver of ModelSim was run using the same DO file.
So the question is, do I need to compile some other libraries?
Am I missing something?
