ADC Value gets changed when a Digital output enables
Thamilarasan
Newbie level 5
I have designed a temp controller. The temp from the sensor is measured and amplified. I have an relay in my circuit.
The relay is connected with the Analog port, but in different pin.
Whenever the relay gets turned on the ADC value gets increased.
The voltage reference is same at all instance.
The chip i have used : Atmega3208.
What will be the cause?
electrical noise may lead ADC value
Impossible to help without schematic and PCB layout / wiring.
My guess: ground bounce.
