D
daskk62
The standard deviation (SD, also represented by the lower case Greek letter sigma σ for the population standard deviation or the Latin letter s for the sample standard deviation) is a measure that is used to quantify the amount of variation or dispersion of a set of data values. A low standard deviation indicates that the data points tend to be close to the mean (also called the expected value) of the set, while a high standard deviation indicates that the data points are spread out over a wider range of values.
I have a code for calculating standard deviation, everything in the codes looks ok, but when I am running the code I am getting some errors, I am using vivado 2017.4 for verilog HDL coding. The screen shot of the error and code.rar is attatched. please hel p me to solve the problem.
