Two ps/2 ports and a FPGA
clros
I would use 2 ps/2 (mini din 6 pin) ports with only one FPGA.
The signal "clock" can be the same for the two ps/2 ports? Can I drive the pins 5 of ps/2 connector with only one FPGA pin?
I don't know. And because of this I'd look into the specifications.
Mainly:
* What voltage levels and drive strength is specified for the PS/2.
* then the FPGA datasheet: is the FPGA able to drive one ... or maybe even two PS/2 in parallel.
Reactions: clros
    clros
PS/2 data and clock lines are 5V level open collector signals (similar to I2C). Can't share clock between two ports, need to provide level converters for 3.3V FPGA IO.
Reactions: clros
    clros
Can you tell me some circuit to do it?
