JalalTN
Newbie
The amount of energy that a wire receives (or emits) depends on its impedance. This impedance is a function of the environment around the wire. A wire laid out above the ground plane is an example of this dependency. If we change the distance to the GND plane, the current flowing in the wire (i.e. during emissions) will change. This impedance is generally different from antenna's impedance. CST microwave/DS does not show this impedance, at least explicitly. Is there any 3D EM simulation that can give this impedance? I want to use it directly in pspice.
