Junus2012
Dear friend, So far I learned from you the setup of Monticarlo, and now I would like to learn how to run the counterpart verification method, the Corner analyses.
Basically I believe that the worst case corners (WP, WS, WO, WZ) must be covered in MC simulation if we take right number of sampling.
I am using three instances in my design, MOSFET, Resistors and Capacitors. However when I click on the model file I still see something like Inductive or Bipolar or diodes which I never used in my design, why it is showing up. Do I simply just ignore it and un-tick it ?
My second problem of making a table covering the all possible corners. As you know MOSFET has (WP, WS, WO, WZ), Resistor has only (WP, WS) and Cap has only (WP, WS).
is it possible to define a corner where some instances have the WP corner and the other have WS ? or all the instances must have the same corner type.
Thank you very much in advance
