drmius
Newbie level 6
Hello all,
I have designed a voltmeter circuit to measure 0 to 5V. I want to display the output on analog display that is, using dial display. For this I plan to use stepper motor to move pointer to correct position. The setup looks as shown in image: . I have written a program to rotate the motor depending on the voltage measured. It doesn't show any error in compilation but when I try to execute the pointer does not move as it should. I have checked voltmeter circuit and it is fine.
The code snippet is attached hereView attachment program.pdfView attachment program.pdf.
Srinidhi
Srinidhi
