D.A.(Tony)Stewart
Advanced Member level 7
- Joined
- Sep 26, 2007
- Messages
- 9,073
- Helped
- 1,825
- Reputation
- 3,649
- Reaction score
- 2,222
- Trophy points
- 1,413
- Location
- Richmond Hill, ON, Canada
- Activity points
- 59,880
In a RC circuit, if the voltage source is a sinusoidal source, I found the given equation. C is constant.
I tried to solve this problem in time domain. So, I use a source in an EDA tool. I found the current in time. I know the voltage. I use simple numerical derivaton df(x)=[f(x2)-f(x1)]/(x2-x1). In this case, derivation is almost zero at the peak and bottom of the sinus. So, capacitance goes infinite. What am I doing wrong?
I dont see an error in result in EDA.
The peak sin voltages will always result in a zero crossing of current for any ideal reactive component. For C, current peak leads voltage peak by 90 deg and for L it lags. It will always be 90 deg phase difference for V and I in any ideal reactance. Even so with variable C changing with V or t, but not if lossy with internal series R (ESR).
