walker5678
Full Member level 3
I have designed an audio power amplifier with CSMC 0.5um process. The designed total current consumption is 3.2mA under tt models, but the fab out device measurement result is 2.7mA. I checked the PCM data and found the main parameter such as Vth, Nwell resistor, Poly resistor are all near typical value. So what makes the difference between the simulation result and the actual result?
BTW, all the current in the curcuit are generated by a bandgap PTAT current source, and should have little dependance on the Vth.
