Can I bias a cascode amplifier with different biasing voltage?
farhanashirin
Junior Member level 1
Hi all,
If i biased the cascode amplifier with different biasing voltage,is there any problem arised?
Plz give ur helpful opinion.
email:farhanashirin@yahoo.com
Re: cascode amplifier
what do u mean , and which device the amp or the cascode device
khouly
cascode amplifier
Can you show the diagram?
if devices are in saturation, it won't be make much difference.
helpfull if you post design
cascode amplifier
you should make sure that it's bias-current is not changed. Then as vinodin said "if devices are in saturation, it won't be make much difference".
