walters
Advanced Member level 2
What are timing capacitors?
capacitors in parallel one side to ground is a storage capacitor
capacitors in series is a frequency dependant
But how are timing capacitors hooked up mostly? in parallel or in series?
For Clocks circuits, 555 timers, oscillators, sample and hold have timing capacitors
What other circuits use timing capacitors please? for TV's?,VCR's?,delay lines? Clocks? oscillators? radios?
Can u please give me some examples of using a timing capacitor to set the "range" and "time duration" of the circuit please?
Added after 5 minutes:
Whats the difference between a timing capacitor VS a filter capacitor in a power supply they both store
Does most timing capacitors have a comparator circuit to set the upper and lower threshold points so it adjusts the charging and discharging times?
