itsallgood
Member level 2
Hi guys,
Sorry about my dumb topic title, i didnt know how to explain it.
I'm thinking of buying one of these usb servo development boards called phidgets:
--- you can see it does more then servos, you can plug LEDs stright into it etc.
It outputs +5vs when on, and 0v when off.
The motor i want to control needs 12volts -- how would it be possible to use the +5v from the "phidget" to work as a switch to control the motor?
I dont know if i'm explaining it right? if not please let me know.
Apart from the one that outputs 5volts, there is one that use's external power from devices, but i dont know if it would be enough:
If anyone could explain (or give a link) on what im trying to do it would be great.
Regards.
found here: **broken link removed**Inputs are activated by 4 to 30 Volt signal. Outputs sink up to 30V at 2A. The outputs do not provide power they just act as switch to ground.
Regards.
