Matlab Programs about Antenna Theory
DEM_MOBILE
Newbie level 2
balanis matlab
Do you have the ISBN Number for this book and/or the actual title?
antenna matlab code
Antenna Theory: Analysis and Design, 3rd Edition
Constantine A. Balanis
ISBN: 0-471-66782-X
antenna theory analysis and design matlab
A program to plot the array factor of linear array
  • array_factor_1136.doc
antenna balanis matlab code cd
i m new in antenna design
Does the array function change if "N" number of lineer antennas change?
matlab programs
would u please share with me a microstrip patch antenna design if u have it e-mail(mohamd_salama2007@yahoo.com)
antenna theory book download
Can anyone tell me how to open the file? I have downloaded the RAR file but cannot open it.
balanis antenna cd
I wonder how to use it?
matlab code for antenna
is there is any fortran code in ur attached file?
matlab antenna
hello mr abdoeng78
yes you can found fortran code for antenna from link:
antenna theory matlab program
is this code can generate the radiation pattern of an antenna?
matlab antenna array
i have e book balanis but there is no codes just comments. i think codes are in CD given with the book. does the attachment include all codes?
Added after 43 minutes:
if anyone has fortran codes, please send me. the matlab codes are working but for question 2.22 in balanis
U = (sin(pi*sinΘ)/pi*sinΘ)²
the result is NaN but the true one is 11.48 dB.
i think there is problem in matlab codes.
antenna theory
i think you should check either .... theta is in degree or radian. In Matlab, by default is in radian. Please convert it to degree.
antenna theory - analysis and design matlap file
Hello chaps! I am new in this Antenna Theory businness and trying to write MATLAB program in a firm related to RF. It is a summer training for me. I wonder and be very pleased if you can tell or show the program on how to write a MATLAB code for 16 element Array Antenna to find the phase and the magnitude of each individual element. The elements have lambda/3 spacing in between. If you couldnt get any part
just inform me so that i reply you back with the better exposition. I really need this. I do appreciate your answer in advance!
rapidshare antenna theory balanis
HI,
Can anyone provide the copy of the book Antenna Theory by C.A.Balanis in pdf format.
Thanks.
HAK.
antenna theory balanis rapidshare
you can download the book from rapidshare
matlab codes for antennas
pls provide the link for the book Antenna: thheory & design by Balanis...
regards
rajhere
antenna array matlab example
HI can u provide me above book plz it is urgent..plz be quick.
matlab code for radiation pattern + pdf
download it from avaxhome
matlab avaxhome 2009
thanks a lot!
about the pdf,I can email you if .....
