seyyah
Advanced Member level 2
There is a 380V star connected ac motor. I apply 3 phase sinusoidal pwm to this motor. My dc bus is 310V. I get ~190V rms voltage when i measure the voltage on the terminals X-Y through a low pass filter (Vxy). This is the fundamental voltage, i think. But when i measure the voltage between one terminal and negative of the dc bus, say Vxn, i get the same value. Is this normal? Since this motor is 380V, my voltage is too low. According to this my dcbus must be ~622V. But in a 380V(l-l) 3 phase system, i can get ~530VDC for dcbus. So what must i do to achieve the rated voltage of the motor? I think one way is, to implement space vector pwm. In this case we can at least reach near the rated voltage. In this case, can't i use 230VAC one phase system to obtain my dcbus to use with this motor? So do the commercial motors, with one phase inputs, use delta connected motors?
