suria3
Full Member level 5
Guys,
I'm designing a buffer (simple differential amplifier with dual input and dual output) which gives the gain of -2dB. Actually i'm desiging this to work as a attenuater where i want to reduce the voltage swing , let say from a 800mVpp to 400mVpp. So, i would say that is not a gain stage at all.
My question is, when i design this circuit, should the be the drain voltage of the tail transistor to be in saturation? My design is showing that my tail is in triode but it is giving a nice differential signal, but if i want that to be that in saturation, i'm getting somehow a distorted differential signal at the bottom. I guess this could be of the voltage margin limitation at the drain voltage of the tail. Meaning that the tail voltage need to be a low as possible.
So, if i design this buffer in triode, is that ok? because we know that any opamp need to be in saturation (tail) in order to have a constant gain, but the one i design not concenrate on gain.
Pls advise on this.
Thanks in advance,
Suria.
Pls advise on this.
Thanks in advance,
Suria.
