syedahmar
Member level 1
hello everybody!!!
i am working on a project and i have been assigned a task and i need some help in that.
Actually i have designed a module in which there are 4 32-bit 1K desth FIFO's. Everything is working fine and i am even able to program it using the JTAG but now my employees want me to test it athardware level. I told my engineer that there are very high number of pins like 32 data input pins,some write enable pins etc.
The engineer said that you can write a code which assigns all the test data and writes it to FPGA during the programming phase and then the output can be checked. Now how can i assign values at memory locations in code. And any suggestions asto how can i check the whole module at hardware level using the available spartan 3 boards?????
i really really need help
Added after 3 minutes:
and the board i have is SPartan-3 Starter Board produced by digilent
