Results 1 to 9 of 9
    Points: 6,571, Level: 19
    Jan 2012
    Italy
    1,173
    6,571
    19
    Need for safe phase margin when dealing with sin input signals
    Hello
    If I am using the instrumentation or operational amplifier to read sinusoidal input sensor signal, why do I need a good phase margin,
    in my opionion, low phase margin below 45 make ring oscillation when we apply pulse signal, but if the input is sin we dont have ringing problem, os even 45 degree should be enough
    Thank you
    Member level 3
    Points: 701, Level: 5
    Mar 2018
    62
    701
    Re: Need for safe phase margin when dealing with sin input signals
    Phase margin also protects from component drift causing control loops
    to break out into oscillation. Power up transients can take longer times
    to settle to final value.
    Phase margin is good :)
    Regards, Dana.
    Points: 11,164, Level: 25
    Nov 2001
    US
    1,001
    11,164
    25
    For sine signal you are ok to use about 60deg of PM. 45deg is probably acceptable too but I won't recommend. 60deg is about max flat response of your amplifier.
    Jan 2012
    Italy
    1,173
    6,571
    19
    Quote Originally Posted by sutapanaki View Post
    Indeed 60 phase margin is also optimum value for pulse signal, this because it offer safe phase margin plus it is the fastest output settle response,
    I was expecting you to say that value of 45 is more than enough for sin signals
    Points: 266,464, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,574
    266,464
    100
    As already stated 45 degree phase margin will be accompanied by gain peaking in closed loop response. If it's no problem in your application, you can implement your amplifier with even lower phase margin. But why would you?
    Nov 2001
    US
    1,001
    11,164
    25
    Quote Originally Posted by Junus2012 View Post
    Actually, for pulsed signals optimum PM is about 75deg. Then you will have fastest settling.
  7. #7
    Jan 2012
    Italy
    1,173
    6,571
    19
    Ok right, gain peaking I should consider
    Thank you FvM
    Thank you Suta
    In behzad book 60 is complained to be the optimum fastest
  8. #8
    Nov 2001
    US
    1,001
    11,164
    25
    What page of Razavi's book? However, 60 is not the fastest for switched caps amplifiers which are working with pulses and steps. 75deg is. Here is a plot of the settling time vs. PM
  9. #9
    Member level 3
    Mar 2018
    62
    701
Name:	Phase Margin Trans Response.JPG
    Regards, Dana.
