Service Notification
EDAboard.com Scheduled Maintenance for 6/4/2020
Starting at 12:00pm EST Thursday June 4th EDABoard will be in maintenance mode and be unavailable. The website is being migrated to a new web server and the software is being upgraded. With the large volume of data & images to move, migration is expected to last for 8 - 10 hours. When started the forum will go into maintenance mode and no posts, edits or registrations can be made.
Results 1 to 3 of 3
    Full Member level 3
    Points: 4,090, Level: 15
    Sep 2002
    Poland, Białystok
    156
    4,090
    15
    Static IP Address and only broadcast packets received
    I can't find the answer for my problem which is as follows:
    I have an appliance that communicates over ethernet (it uses ENC424J600 chip). It has static IP address assigned by network administrator. It works in server mode and uses UDP only.
    The problem is that it receives ARP requests correctly but other packets never reach my device. I can receive packets with broadcast MAC addresses only. When I send "ping" command it doesn't work either. The network administrator told me I need subnet mask to be set correctly in order for my appliance to be detected in the network. But I can't see any point of incorporating subnet mask into my device as it does not need it - it works only as a server and never initiates any transmission on its own. It only responds to UDP incoming packets. What do I do wrong ?
    Newbie level 2
    Points: 19, Level: 1
    May 2020
    19
    Re: Static IP Address and only broadcast packets received
    You can try to reset to the main customs of your settings.
    Points: 8,022, Level: 21
    Jul 2010
    Sweden
    1,077
    8,022
    21
    You must set a subnet mask, so the device can understand that it communicates with a unit on the same subnet. Set it to 0.0.0.0 to put all IP addresses in the same subnet.
    You should only set the subnet mask to 0.0.0.0 if you have a "private" subnet without connections to other subnets.
    If you communicate with the device from another subnet, both the subnet mask and the gateway must be set correctly.
