kekon
Full Member level 3
- Joined
- Sep 19, 2002
- Messages
- 155
- Helped
- 5
- Reputation
- 10
- Reaction score
- 3
- Trophy points
- 1,298
- Location
- Poland, Białystok
- Activity points
- 1,493
I can't find the answer for my problem which is as follows:
I have an appliance that communicates over ethernet (it uses ENC424J600 chip). It has static IP address assigned by network administrator. It works in server mode and uses UDP only.
The problem is that it receives ARP requests correctly but other packets never reach my device. I can receive packets with broadcast MAC addresses only. When I send "ping" command it doesn't work either. The network administrator told me I need subnet mask to be set correctly in order for my appliance to be detected in the network. But I can't see any point of incorporating subnet mask into my device as it does not need it - it works only as a server and never initiates any transmission on its own. It only responds to UDP incoming packets. What do I do wrong ?
