Results 1 to 18 of 18
    Points: 49, Level: 1
    Feb 2020
    49
    Old capacitor needs replacing not sure what to replace with.
    I renovate cine projectors, and I have come across the below capacitor which has three leads and not sure what to replace it with, anybody got any ideas.
    Hunts
    Capacitors
    0.1+0-005+0.005
    25v A.C Wkg
    to B.S.S.613
    List No. Z497 A
    11W
    Three wires two reds and green
Name:	Specto 500 Capacitor.jpg
    Points: 81,871, Level: 69
    Apr 2014
    16,622
    81,871
    69
    Re: Old capacitor needs replacing not sure what to replace with.
    The wiring and the values are shown on the capacitor.
    You may try to find a similar one or use three capacitors.
    EMI suppression capacitors
    * type X between L and N
    * type Y between L and Earth, N and Earth.
    Points: 54,106, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,185
    54,106
    56
    The casing has a schematic of 3 capacitors with internal connections:
    0.1 uF
    .005uF
    .005uF
    25 VAC Wkg means it was made to endure 25VAC working voltage. It's paper type. Non-polarized.
    11W suggests it was made to carry 11 Watts. This suggests it heats up. (I could be wrong.)
    Points: 83,881, Level: 70
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,805
    83,881
    70
    The chances of finding an exact replacement are virtually zero but as Klaus suggested, you can replace it with three single capacitors. Wire it exactly as on the body diagram:
    0.1uF (=100nF) across the two brown wires
    0.05uF (=50nF) from each brown wire to the green wire.
    They should be rated for 250V AC ! (or higher - 275V AC is the modern standard)
    The BSS613 is a reference to British Standard Specification 613 which relates to interference supression devices.
    I would guess 11W is a date code, I doubt it refers to a power rating.
    Note that although 50nF is available, the more common equivalent standard value these days is 47nF, it will work equally well.
    Points: 15,453, Level: 30
    schmitt trigger's Avatar
    Apr 2013
    2,572
    15,453
    30
    I am with Brian, that MOST LIKELY the rating is not 25VAC, but 250 VAC.
    What happened to the wire insulation? And the loose wire strands in the bottom left corner?
    That looks like an accident waiting to happen.
    My batteries are recharged by "Helpful Post" ratings.
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    13,805
    83,881
    70
    I've seen this before, it probably dates back to the 1950's or very early 60's before PVC was used for insulation. The wires are covered in some kind of rubber insulation that dries out and fractures (nearly used the banned c**** word then!) especially in hot environments. The rheostat would probably make the whole thing quite hot and prone to failure. After fracturing, chunks of the insulation crumble and just fall off.
    Sadly, the same insulation was used in house wiring, safe if left alone but it disintegrates wen touched.
  7. #7
    Points: 7,901, Level: 21
    Jul 2010
    Sweden
    1,060
    7,901
    21
    The small capacitor is 0.005 uF = 5 nF, so 4.7 nF should be a good replacement.
    It must be of type "Y" for safety reasons.
  8. #8
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    13,805
    83,881
    70
    Must be my eyesight failing... yes, it is 5nF although 50nf would probably work better.
    There is a small 'Y' near the value and a small 'X' near the 100nF.
  9. #9
    Feb 2020
    49
    Got all new silicon covered wire, safe up to 200 degrees in all the colours needed, for any wire that needs replacing.
  10. #10
    Feb 2020
    49
    So I have taken another image just to confirm I would need 3 capacitors to replace this one not sure there would be enough space in the base for three. Will look at some sizes of them.
  11. #11
    Points: 8,643, Level: 22
    Nov 2009
    Italy
    1,160
    8,643
    22
    For safety reason the class X and Y must be respected. Since the class Y capacitors are connected between line and earth they cannot be too high in value in order not to generate high leakage current. A capacitor of 5 nF has an Xc of about 650 K at 50 Hz, that means an rms current of 240/650k = 375 uA.
  12. #12
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    13,805
    83,881
    70
    Look here at the 'Wima' branded capacitors.
    https://www.rapidonline.com/Catalogu...1;%22250V%22]}
    They are actually quite small. If the appearance of the unit isn't important after repair, you could consider using an IEC mains filter. You can get them with in/out tags or with a built in mains socket to take a standard 3-pin IEC plug. If you use a chassis mounted IEC filter, make sure it is securely bolted down to the projector chassis because it forms the Earth connection through it's mounting holes.
  13. #13
    Points: 265,300, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,356
    265,300
    100
    X/Y capacitor combis are still made today, like this device from RIFA/Kemet https://www.distrelec.de/en/xy-combi...r04/p/11040274
    Different PZB300 types are available.
  14. #14
    Feb 2020
    49
    So I think I have found the ones, two of the first 50nf going from each brown wire to the green and one 100nf across the two brown wires. I assume that the Y2 and X2 sub standards don't make much difference to my install as X2 is ≤2.5kV and Y2 is 150VAC≤ V<300VAC Rated Voltage.Both appear to be above what I need.
  15. #15
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    13,805
    83,881
    70
    They should be fine. They exceed the rating of the originals and are also probably more reliable and effective than the original type too.
  16. #16
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,356
    265,300
    100
    As explained in post #11, the capacitance of the Y capcitor shouldn't be larger than 5 nF to avoid too high ground leakage current.
  17. #17
    Feb 2020
    49
    Hi All so below is my solution to replacing the capacitors, might not be how others would do it but it is based on the information I got will try it late once I have tested it with Pat Tester I have.
  18. #18
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    13,805
    83,881
    70
    Looks good to me and it should be far more reliable than the old one!
