How does HFSS derive the distribution of electromagnetic fields, such as Hz?
x529
Junior Member level 3
Using field calculator, calculator the Hz.
result,
3D Hz picture
134cc038c096da425c228b987147bba.png,
how can I derive the distribution of electromagnetic fields, such as Hz, I want to put it in paper, like this
Thanks!
Welcome x529,
Your function is slightly off. You probably want something like Hz = AtPhase(ScalarZ(Smooth(<Hx,Hy,Hz>)),Phase), if you want a phase-dependant magnitude.
If you want complex magnitude, try Hz = CmplxMag(ScalarZ(Smooth(<Hx,Hy,Hz>))).
Good Luck!
Reactions: x529
    x529
