Results 1 to 7 of 7
    Points: 73, Level: 1
    Oct 2019
    8
    73
    ADS schematic to layout
    Hello ,
    how to generate proper layout from this schematic ? i need to make layout so i can export the gerber file.
    Note : Both are the same just rearranged.
ID:	156729Click image for larger version.
    Points: 14,440, Level: 28
    Apr 2014
    2,255
    14,440
    28
    Re: ADS schematic to layout
    Quote Originally Posted by Nighty123 View Post
    This has been asked by other students working on the same topic many times before: It is not possible because you have zero layout information in your design.
    If you want to do the layout in ADS, you need to use components model with associated footprints. This can be a component library like Murata, or components from palette "Lumped-With Artwork".
    Or use any other PCB package, the circuit is trivial enough and interconnect routing must be done manually anyway.
    Oct 2019
    8
    73
    Thanks sir for your reply,
    what do you mean by other PCB package ? do you mean other software like eagle,kicad...etc ?
    also is it possible to make the layout manually by putting transmission line between each lumped component or it's useless ?
    Points: 30,738, Level: 42
    BigBoss's Avatar
    Nov 2001
    Turkey
    4,509
    30,738
    42
    Are you sure that you will able to find HSMS2850 Schottky Detector Diodes ?? They are obsolete coming form HP days..
    Apr 2014
    2,255
    14,440
    28
    Yes
    Yes, that is the RF engineer's use of ADS, to include these elements in simulation (!) to see their effect on simulation results (!) and then create that (!) layout.
    Oct 2019
    8
    73
    Thanks for you concern sir, but i have them already
  7. #7
    Oct 2019
    8
    73
    Quote Originally Posted by volker@muehlhaus View Post
    so what should i do now is include TL and see the results on ADS then i move to another PCB software to be able to make the gerber file.
