Results 1 to 13 of 13
    Full Member level 1
    Points: 958, Level: 7
    Jan 2017
    97
    958
    7
    $freq while using AC analysis to access lookup table
    Hello all,
    I have saved in a table the response of a filter. The table contains 2 columns; the first contains the frequency and the second the corresponding magnitude.
    I am building a model that will instantly "read" the value of the frequency during an AC analysis and using that value will find the corresponding magnitude through the table.
    My thought was using something like $table_model( $freq, "table_link.dat") and assigning that value to the output, but it doesnt seem to work. Actually it seems like the only value of frequency is 0Hz.
    Any ideas?
    Thank you in advance
    Points: 264,250, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,176
    264,250
    100
    Re: $freq while using AC analysis to access lookup table
    Forgot to mention the circuit analysis tool.
    Points: 17,685, Level: 32
    pancho_hideboo's Avatar
    Oct 2006
    Real Homeless
    2,722
    17,685
    32
    Quote Originally Posted by NikosTS View Post
    If you mean Verilog-A, $freq is not available in Verilog-A.
    https://www.edaboard.com/showthread.php?373837#6
    Full Member level 1
    Jan 2017
    97
    958
    7
    Thank you both for the replies.
    I use Spectre if that is what you mean.
    Quote Originally Posted by pancho_hideboo View Post
    Yes I am using verilogA to model a filter.
    Is there any other way to search a table using frequency as the input?
    Oct 2006
    Real Homeless
    2,722
    17,685
    32
    Use spectre primitive, nport.
    If you use Keysight ADSsim, use DAC(Data Access Component).
    https://www.edaboard.com/showthread.php?364412/page2#23
    Full Member level 1
    Jan 2017
    97
    958
    7
    Thank you pancho, nport is indeed a way to associate frequency with magnitude. But it cannot be "translated" in VerilogA.
    Is there a way to only use VerilogA in order to manipulate the sweeped frequency and get the wanted magnitude?
  7. #7
    Oct 2006
    Real Homeless
    2,722
    17,685
    32
    If you insist on Verilog-A, instantiate spectre’s primitive nport in Verilog-A.
    https://designers-guide.org/forum/Ya...m=1574240440#2
    Other possibility is “deriv(ac_stim(1))/(M_TWO_PI)”.
    I don’t know whether it works as independent variable for table_model().
  8. #8
    Full Member level 1
    Jan 2017
    97
    958
    7
    Hello and thank you for the reply.
    Instantiating the nport in VerilogA seems like a very good way to get the response I want. However, I can only connect the ports by order and not by name.
    Specifically:
    I want to instantiate an nport with 2 ports and NO common reference. The instance will have 4 pins : p1,m1,p2,m2 (at least in schematic editor ).
    My VerilogA model has 4 pins also : INP,INN,OP,ON and I want to connect port (p1 with INP) , (m1 with INN) , (p2 with OP), (m2 with ON).
    My code works and simulates correctly when I instantiate the nport as :
    nport #(params) NPORT0(INP,INN,OP,ON )
    but produces an error when I try to instantiate it as:
    nport #(params) NPORT0(.p1(INP),.m1(INN),.p2(OP),.m2(ON) ) .
    Any ideas on this?
  9. #9
    Oct 2006
    Real Homeless
    2,722
    17,685
    32
    Compare CDF parameter and spectre -h nport.
    Or simply use gnd node in Verilog-A.
    Ground node declaration.
  10. #10
    Full Member level 1
    Jan 2017
    97
    958
    7
    Indeed the corresponding CDF parameters were not the same as the pins of the nport.
    For anyone's interest : pins p1,p2,p3... etc must be instantiated as port names t1,t2,t3... and pins m1,m2,m3.... as b1,b2,b3...
  11. #11
    Oct 2006
    Real Homeless
    2,722
    17,685
    32
    `include "constants.vams"
    `include "disciplines.vams"
    module my_freq(out);
    output out;
    voltage out;
    electrical gnd;
    ground gnd;
    voltage hoge;
    analog begin
       V(hoge) <+ ac_stim();
       V(out) <+ abs( ddt( V(hoge) ) ) / `M_TWO_PI;
    end //analog
    endmodule
    Try this code.
    You can get analysis frequency value in Verilog-A.
    Also I showed gnd node definition in Verilog-A.
    nport #(params) NPORT0(.t1(INP),.b1(gnd),.t2(OP),.b2(gnd) )
  12. #12
    Oct 2006
    Real Homeless
    2,722
    17,685
    32
    Correction.
    output out;
    voltage out;
    electrical gnd;
    ground gnd;
    voltage aho, boke;
    analog begin
       V(aho) <+ ac_stim();
       V(boke) <+ ddt( V(aho) ) / `M_TWO_PI;
       V(out) <+ abs( V(boke) );
    end //analog
    endmodule
  13. #13
    Full Member level 1
    Jan 2017
    97
    958
    7
    Correction.
    output out;
    voltage out;
    electrical gnd;
    ground gnd;
    voltage aho, boke;
    analog begin
    end //analog
    endmodule
    Hello pancho thank you for the reply,
    I havent had the time to test that piece of code but I am not sure if it will help me anyway. The nport way works really well until now!
