Results 1 to 4 of 4
    Junior Member level 3
    Points: 241, Level: 2
    Jul 2019
    27
    241
    Temperature mobility degradation factor (c) - MOSFET SOI
    There is an equation that I can't find in any book or scientific article referring to the letter '' c '', what is the origin of it if there is a calculation behind or something? I would very much like that source that explains itself broadly on the subject. Or at least the equation of (c).
    It is related to zero temperature coefficient [ZTC]
    Eq:
    μn2 = μn1*(((T1)/(T2)))^(c)
    Advanced Member level 2
    Points: 5,700, Level: 17
    Feb 2008
    553
    5,700
    17
    Re: Temperature mobility degradation factor (c) - MOSFET SOI
    This is an empirical equation or model, describing a temperature dependence of carrier mobility.
    Mobility decreases with temperature, that's it.
    "C" is a fitting parameter, that hsould be found from fitting the model to the measured characteristics.
    Jul 2019
    27
    241
    Quote Originally Posted by timof View Post
    Thank you very much for your help.
    If you can indicate a reference book or article say about point that it is impiric.
    Really did not find.
    Feb 2008
    553
    5,700
    17
    Any textbook on semiconductor physics will have something on this topic.
    Or you can look it up at Wikipedia:
    https://en.wikipedia.org/wiki/Electron_mobility
    Check the section on "Temperature dependence".
