Results 1 to 9 of 9
    Full Member level 5
    Points: 4,054, Level: 15
    May 2006
    275
    4,054
    15
    [HFSS] MagE and CmplxE
    just to be sure, could someone comment on the difference between magE and cmplxE in HFSS.
    Thank you very much.
    Best regards
    -e
    Full Member level 5
    May 2006
    275
    4,054
    15
    Re: [HFSS] MagE and CmplxE
    E(x,y,z,t) = Epeak(x,y,z) * cos[wt + phi(x,y,z)]
    I guess HFSS is using Epeak(x,y,z) in case of magE. Using animation the cos-term is multiplied.
    Does anybody know the difference to cmplxE. In the latter case, animation is not possible, result does not depend on time.
    Points: 904, Level: 6
    Oct 2015
    34
    904
    MagE is a complex number. "Mag" here indicates the vectorial magnitude, ie. sqrt(reEx+reEy+reEz)+i*sqrt(imEx+imEy+imEz)
    ComplexMag is a real number, and it is the absolute value of MagE.
    MagE is a complex number so it can be animated wrt time.
    ComplexMag is a real number, it cannot be animated wrt time.
    ..i think
    Full Member level 5
    May 2006
    275
    4,054
    15
    Thank you.
    Ansys answered: magE=magnitude of complex number, cmplxMagE=averaged over all phases
    Full Member level 3
    Points: 3,265, Level: 13
    Dec 2007
    187
    3,265
    13
    Quote Originally Posted by elektr0 View Post
    Thank you.
    This answer is not clear. It is better to look at their definitions:
    Mag_E is defined as Mag(AtPhase(Smooth<Ex, Ey, Ez>, Phase))
    ComplexMag_E is defined as Mag(CmplxMag(Smooth<Ex, Ey, Ez>)) or Mag(Smooth<Ex, Ey, Ez>) in new HFSS versions
    Both two parameters correspond to Etot due to the Mag() operation.
    The difference between Mag_E and ComplexMag_E can be simply described by the equation: Mag_E = ComplexMag_E * cos(Phase)
    Full Member level 5
    May 2006
    275
    4,054
    15
    Mag_E = ComplexMag_E * cos(Phase)[/QUOTE]
    Hi, but then the CmplxMag result should be identical to at least one MagE result, but this is not the case ?!
    -e
  7. #7
    Points: 14,740, Level: 29
    Apr 2014
    2,297
    14,740
    29
    -e
    Phase varies with time and location
  8. #8
    Full Member level 5
    May 2006
    275
    4,054
    15
    Quote Originally Posted by volker@muehlhaus View Post
    True, so Volker you agree with streamlet.
    Fine for me, thank you all very much!
    Even if it the answer from support was different...
    -e
  9. #9
    Full Member level 3
    Dec 2007
    187
    3,265
    13
    -e[/QUOTE]
    It is. Taking a rectangular cavity resonator working at TE101 mode and excited by 1-V/m E-field with 0-deg initial phase for instance, you will see the Mag_E@0 deg is the same as ComplexMag_E, and Mag_H@90 deg is the same as ComplexMag_H.
