Results 1 to 2 of 2
    Newbie level 3
    Points: 970, Level: 7
    Nov 2014
    8
    970
    7
    Maximum vehicle speed.
    Please I want the solution for the question below:
    Consider a mobile wireless system, using QPSK modulation at 25 Ksymbols/s, and a carrier frequency of 1900 MHz. What is the fastest speed in km/h that is permissible for a vehicle using such system, if its required that the change in phase due to Doppler spread does not exceed 5 degree/ symbole?
    Advanced Member level 1
    Points: 2,389, Level: 11
    Jan 2019
    442
    2,389
    11
    Re: Maximum vehicle speed.
    if this is a homework question, say so
    guidance:
    at your symbol rate, what is the time per symbol?
    how much time per symbol is a 5 degree shift?
    doppler shift:
    https://en.wikipedia.org/wiki/Doppler_effect
    the radar section
    remember that radar requires the return signal, while you do not
