Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
  1. #21
    Full Member level 4
    Points: 1,088, Level: 7
    May 2019
    Roskilde, Denmark
    235
    1,088
    7
    Re: Ohm's Law and Power calculation problem
    As a service for the persons reading this post, I made the following calculations:
    I took the first full pulse from the data file (SDS00001.CSV attached in previous thread) and it looks like this
Name:	Screenshot from 2019-11-11 15-18-18.png
    Then I inverted the current by multiplying it with -1 and the result looks like this
Name:	Screenshot from 2019-11-11 15-53-49.png
    Note that the current still goes negative while the voltage is positive.
    Then I calculated instantaneous power P = U * I and energy ∫P
Name:	Screenshot from 2019-11-11 15-54-22.png
    And I calculated the resistance R = U / I
Name:	Screenshot from 2019-11-11 15-55-21.png
    Note that the resistive spike occurs at the same time as the current crosses zero.
    If I in fact have turned the CT the wrong way, then I would really have a "pertuum mobile" in my hands as the output energy would be 2.45J while input is 50mJ (calculated excluding losses i.e. the final amount of energy that enters "R") i.e. 4900% efficiency. So logic dictates that I could not have turned the CT the wrong way around, hence I still believe we are talking about true negative resistance.
    In general, it may also be noteworthy that if the resistor "R" is disconnected from the source it behaves just like any ordinary resistor and has a resistance of 883K ohm.
  2. #22
    Points: 17,814, Level: 32
    Nov 2012
    3,251
    17,814
    32
    Please explain: if you are using R(t)=U(t)/I(t) to calculate the resistance, I have no problem. But the 4th graph is misleading, because you are trying to plot a point where the R becomes infinite.
    Such points are singular and must be skipped in the plot. That happens when you have a finite U(t) but the current I(t) becomes zero, you have this problem.
    The reason is simple: if the U(t) or I(t) are not constants in time, they must be treated as a complex quantity. Then R(t) is also complex and has a real and imaginary parts. At the singular point, the real and imaginary parts are equal and opposite.
    Such behaviours are common whenever there are reactive components.
  3. #23
    Full Member level 4
    May 2019
    Roskilde, Denmark
    235
    1,088
    7
    Quote Originally Posted by c_mitra View Post
    Yes that's how it's calculated.
    Yes, I agree in the case of singular points, but 6.7e10 as in the plot is still finite.
    And what if both U(t) AND I(t), as the case is here, are not constants in time?
  4. #24
    Nov 2012
    3,251
    17,814
    32
    What you have done is called point-wise division. This may not be same R(t)=U(t)/I(t) under some conditions. Particularly near singularities. I won't go into these details. Recall that division by zero is not defined.
    In computer, we can define a zero but not infinity because infinity is not a number. You can see what I mean if you convert the y-axis scale to a log scale.
    Your system has a natural frequency and it is damped poorly. You can approximate the system as a resistor far from this frequency (on both sides): but how far is far enough?
    You must know the waveform: in other words, the voltage a moment back has an effect on the current at the present moment (if your circuit is reactive). Because of Ohm's law, only two of the three (U,I and R) are independent.
    Just for fun:
    Consider U(t)=1+2*t (a simple ramp); the current is also a simple ramp: I(t)=2+1*t; what will be R(t)??
    If R(t) is constant and real, then I(t) is automatically defined for all t. But how about Re(R(t)) is constant and Im(R(t)) is also constant (but non-zero)??
    Simple questions do not have simple answers. I will stop here.
  5. #25
    Points: 262,101, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,809
    262,101
    100
    The calculations and respective conclusions are presuming correct I and U measurements.
    Particularly the current measurement is very implausible, see previous discussion, e.g. post #12.
  6. #26
    Full Member level 4
    May 2019
    Roskilde, Denmark
    235
    1,088
    7
    Yes, but in this data series, the current is never zero, otherwise the calculating script throws a divide by zero warning, which it doesn't in this case. - so no zeros.
    As I have said several times, and as it can be seen in the trace, before the pulse - both current and voltage are zero. And the pulse in the trace is the very first after power on.
    Yes I can agree.
    I'm presuming the measurements are correct until there is valid reason they are not. So far I have not heard any valid reason, "impossible" and "implausible" are not a valid reasons, they are just empty statements, so I kindly ask you to be more serious.
    For which valid reason are you making that claim?
    I agree with KlausST that the current measurement channel seems to be inverted. I' d think about possible alternative explanations if I see the pulse response form the start.
    You have seen the pulse from start in #21, so I'm still waiting your sentiments.
    Since it is in my interest the measurements are correct, I would like to propose that I drop by your lab at your convenience, where you can repeat the measurements with your own apparatus, and even examine the source to your personal satisfaction. And if you don't work for free - then give me your price.
    Actually I would personally prefer if the current was positive all the way, I have no use for negative current.
  7. #27
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,809
    262,101
    100
    I gave some hints why the current waveform is likely to be distorted by the characteristic of the transducer. There may be more problems with your circuit that are not so obvious at first sight.
    In my view, the final prove that voltage and current waveforms are not consistent is the apparent "resistance" you have calculated. At this point, it's pretty clear that the measurement function needs to be validated from the very bottom.
  8. #28
    Nov 2012
    3,251
    17,814
    32
    It need not be exactly zero; in floating point asthmatics, you test for zero with a small number.
    when both current and voltage are zero, what is the calculated value of the resistance?
    Hint: all physical measurements take time and all the results are simple averages over the measurement time period.
  9. #29
    Full Member level 4
    May 2019
    Roskilde, Denmark
    235
    1,088
    7
    So you are stating a personal opinion, and because of that opinion it's clear to you that measurements are wrong and therefore you can't be bothered to look at the facts even for all the money in the world.
    It makes me think of this Leo Tolstoy quote:
    “I know that most men, including those at ease with problems of the greatest
    complexity, can seldom accept even the simplest and most obvious truth if it
    be such as would oblige them to admit the falsity of conclusions which they
    have delighted in explaining to colleagues, which they have proudly taught to
    others, and which they have woven, thread by thread, into the fabric of their lives.”
    Then you have a serious singularity problem.
    How can a single point in time measurement be an average?
    Anyway I'm getting fed up by this thread, it's generating NOTHING of value. I will declare it as [SOLVED].
    For those who have a sincere technical interest in the subject, please feel free to contact me by PM, this is apparently not a subject for public consumption.
  10. #30
    Nov 2012
    3,251
    17,814
    32
    That is the point I am trying to convey: it is not possible to measure any quantity in ZERO time; all physical measurements take time to perform.
    No, it is still defined. Consider a sine wave applied to a pure resistor; the current and voltage graphs will be same (except for a scale factor). The resistance value will still be known when the voltage is zero (say at t=0).
    if U(t) =a sin (alpha t) and I(t) = b sin (alpha t), R(t) = a/b but at t=0, it is 0/0. You need to use l'Hospital rule to get R(t=0)=a/b.
    I too give up.
  11. #31
    Full Member level 4
    May 2019
    Roskilde, Denmark
    235
    1,088
    7
    Well, that trick I didn't know, so thank you for that.
    Then it's only fitting that I amend my statement to "it's [this post] generating VERY LITTLE of value"
