What is the size of terminal connector
As depicted on datasheet, pin dimensions are 0.5x0.9mm, whereas the recommended hole diameter (in fact not so clear) is 1.1mm.
Reactions: Fan174
    Fan174
Okay so when I click on the symbol I get property window. Where to set hole diameter in window
The above snapshot refers to the positioning properties of the component (apparently on schematic viewer), does not get into the component details. To do so, you must edit it in the library editor.
By the way, doesn't it seem obvious to you that it would be useful to mention what CAD you are using?
