Closed loop gain of this fully-differential amplifier
tenso
I am trying to figure out how Razavi in his book got the following expression for Closed loop gain of a fully diff. amplifier. The circuit schematic and the equation are below.
I have come across this explanation of the calculation of the feedback factor of an inverting amplifier. This is the first time I am seeing the factor "k" being mentioned in the closed loop voltage gain.
https://electronics.stackexchange.c...inbeta-derivation-for-the-inverting-amplifier
is there any book which talks about this?
NVM, after looking at this link https://electronics.stackexchange.com/questions/330638/beta-of-inverting-opamp-amplifier
I figured out how he got the expression.
Am I right about the taylor series approximation though? It is taken when x <<< 1?
I don't know how he got to the second line. He may have used the Taylor series or perhaps long division.
However, note that the result is approximately - R2/R1 Vin if the open loop gain is very high.
I have attached an analysis of a diff in, singled out amp that I did years ago. I used this method to analyse your amp.
Hope this helps
Yes.. If A0 is large (and is typically the case) then the 'x' term will be such that x<<1..
Of course, we do not need any Taylor series approximation or something like this.
We need only the classical feedback formula (for finite gain) introduced by H. Black - supplemented by a forward damping factor.
