Results 1 to 3 of 3
    Advanced Member level 2
    Points: 3,754, Level: 14
    Created Album pictures
    Dec 2013
    Sweden
    572
    3,754
    14
    USB PD Lab Power Supply, flyback- vs forward-converter, pro's vs con's?
    Hello.
    I have what I think is a pretty neat idea, the latest laptop I bought feature a USB Type-C port which supports USB Power Delivery(USB PD)(my port is actually a Thunderbolt 3 port but it is compatible with USB 3.1 Gen 2 & USB PD, but let's not get into all that stuff) which means the such a port is capable of supplying up to 20V @ 5A or 100W of power.
    I have made a picture to show what I have in mind:
Name:	usb pd power supply concept.png
    That is obviously a very simplified concept picture but it only shows my intention at large, I might go for using TI C2000 microcontrollers for the converters.
    In any case, I have been reading about flyback- vs forward-converters and it appears to me that a forward-converter is what is most suitable for me, a two-switch forward converter that is, due to the lower output ripple, but there are so many considerations that I can't remember them all.
    But I want to ask, is there any difference in the difficulties in successfully designing a flyback- vs forward-converter? Is the feedback compensation more difficult in a flyback converter?
    As far as I can understand the two-switch forward converter is limited to duty-cycles below 50%, though I don't really grasp the implications of that, I mean as long as I choose a suitable turns-ratio that shouldn't be a problem right?
    (I feel as though I am forgetting to ask the main question motivating this thread but I can't recall it..)
    I have lost the picture I intended to post, the two channels are isolated and they should each be able to handle 3A output in case only one is used. I shouldn't have posted right now, I feel as though I have forgotten all the main points I wanted to describe.
    Points: 52,942, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    12,948
    52,942
    56
    Re: USB PD Lab Power Supply, flyback- vs forward-converter, pro's vs con's?
    Weigh the risk if you attach homebrew circuits to your computer's USB port. You could ruin it. Switched-coil supplies are the type that ought to have a snubber, due to indcutive spikes.
    Another question is how much current you can get immediately from your USB. There's a protocol called enumeration. If a device does not complete it, then the port only provides 130 mA. It was that way not so long ago, maybe it's changed.
    Points: 14,971, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,488
    14,971
    29
    which means the such a port is capable of supplying up to 20V @ 5A or 100W of power.....
    I have to ask: an USB port is capable of providing 20 volts ?
    My batteries are recharged by "Helpful Post" ratings.
