Page 1 of 2 1 2 LastLast
Results 1 to 20 of 27
    Points: 314, Level: 3
    Antor's Avatar
    Mar 2019
    51
    314
    IGBT Overshoot and Weird Slope
    I'm trying to build a 3phase-3phase direct converter (Explains my schematics). I'm testing IGBT stage with DC source. Circuit is now just triggering IGBT named SAAF.
    Cutting to the chase, I'm triggering only 1 IGBT and chopping a DC for now. I'm sure there will be negative undershoot if I trigger SAAR negative path IGBT too.
    There are 3 problems;
    1- Overshoot
    2- Very bad transient
    3- A weird slope after turn-on.
    Here is main schematic and its's chield
ID:	155508Click image for larger version.
    These are the PCB with top and bottom layers
ID:	155511Click image for larger version.
    Signal triggering the IGBT driver (HCPL3140) is generated by signal generator. 5V %50 duty cycle @1KHz
    Load is a rheostat (around 10ohms, may varry)
    Yellow : Output of the IGBT, Blue : Signal triggering IGBT (HCPL3140 output)
    DC source of the IGBT 1A/24.2V, Output have an overshoot and a weird slope during on cycle. PWM signal is not in a good condition also.
Name:	003- 1A 24.2V.jpg
    DC source of the IGBT 1.24A/30V, Output have an overshoot and a weird slope during on cycle. PWM signal slightly better.
Name:	005- 1.24A 30V.jpg
    DC source of the IGBT 1.33A/31.7V, Output have an overshoot and the weird slope is gone.
Name:	001- 1.33A 31.7V.jpg
    Close shots of overshoot and transient state of turn off
ID:	155516Click image for larger version.
    Workspace
    How can I condition the output ?
    Cake is a lie
    Points: 77,731, Level: 67
    Apr 2014
    15,759
    77,731
    67
    Re: IGBT Overshoot and Weird Slope
    There are electronic devices called capacitors.
    Do you know them?
    Added:
    Your schematic violates general rules how to use gate drivers as well as IGBTs.
    The same applies for the PCB layout.
    Every IGBT manufacturer provides datasheets, application notes and design notes how to use IGBTs.
    Every driver IC manufacturer provides datasheets, application notes and design notes how to use IGBTs.
    All the infirmations are free to use and are very urgent for proper operation.
    I strongly recommend to read through them and follow the informations.
    Advanced Member level 2
    Points: 2,884, Level: 12
    Aug 2016
    507
    2,884
    12
    I will only point out things that I think may be direct contributors, so the list is not exhaustive but just a starting point.
    =Your IGBTs are not properly connected.
    =See the "Applications Information" section of the driver datasheet and follow the recommendations there. Your PCB layout is poor. Also take note of Figure 19.
    =You haven't mentioned what the gate driver supply voltage is. Look at that again.
    =Your test points and signal supply points: The wires that you are connecting your signal generator and oscilloscope probes to are way too long. Are they even soldered? Pogo pins are preferrable.
    That GW INSTEK power supply is a switched-mode type power supply (do not doubt this, I have it) with a lot of ripples. You need to properly decouple them.
    =I do not understand why the triangular waveform of your signal generator is active instead of the square wave. That does not correlate with the near square wave that is being displayed on the scope though but you may need to consider checking that out. I also see a type of output labelled "GATE", maybe you should check what that is. Have you properly tuned you oscilloscope and other BNC probes that you are using?
    =The peforated metallic stuff lying on the bench to the left of your setup, what's that? Hope it's not a source of EMI.
    --Akanimo.
    Points: 11,060, Level: 25
    Aug 2015
    1,806
    11,060
    25
    you appear to have no caps across the DC bus ...
    Aug 2016
    507
    2,884
    12
    Quote Originally Posted by Akanimo View Post
    Let me elaborate more on this very point. Each of your HS drivers need a bootstrap circuit. Look at your schematic again. You need to rearrange the whole schematic.
    --Akanimo.
    Points: 260,203, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,203
    100
    There's no DC bus in a "direct converter", which constitutes already some of the circuit problems.
    It's not clear where you measure the "IGBT output". Why we see a negative pulse although the positive switch SAAF is operated?
    According to oscilloscope waveform, overshoot occurs on turn off. Overshoot can be expected with unclamped switching of the inductive rheostat load. Don't know what's the intended final converter application. Some means to clamp inductive overvoltage may be required to protect the IGBTs, e.g. active clamping.
    You seem to supply the gate drivers by an external power supply, may be even a lab supply. Did you realize that the gate driver supply must have low output capacitance and sufficient isolation for mains voltage? A dedicated gate driver DC/DC converter should be used.
  7. #7
    Antor's Avatar
    Mar 2019
    51
    314
    Thanks for reply mate. Going down the list one-by-one. Sorry if sometimes I look rude, it is unintentional and caused by my lack of english skills.
    It is not an DC-AC inverter, it is an AC-AC converter. IGBT's connected the way how a bidirectional switch operates. The PCB is (3Pin 1Pout) only 1 phase power module of a 3Pin3Pout system.
    I preferred common emitter bi directional switch, because common collector topology needs complex connections between all power modules. Drawback here is I need 9 isolated DC sources (for 3x3) instead 6. But testing layers seperately is avaible with common Emitter IGBT driver source is 0-15V.
    According to datasheet and my need (peak Ig current 0.6A) Rg > (15-5)/0.6 = 16,67, so Rg choosen as 22ohm to reduce a bit emi.
    If we are talking about same Figure 19 below, please consider that I'm not using the topology on figure 19.
    PCB layout is poor if you say so, I have no experience on this. Could you point out my PCB mistakes so I can redesign and order again ? I couldn't find a good source to read about PCB design, so I tried to avoid drawing coils as much as I can.
    It's 15V, since I'm using low power IGBT I don't need negative voltage to turn-off. And yes, my isolated 15V sources schematic is below. There is bulk and hf cap at Vout, ready for PWM (I think).
    The wire I'm using for signals are shielded cables (6x0.22). Circuit and cables are earthed. Earth cable yes, it's long and consist of few bad condition cables.
    What is to be decoupled ? If I decouple signal generator output doesn't it delay the signal ? Decoupling the output of HCPL3140, I guess it causes delay too. I guess I need a bit help in here.
    Do I need shorter oscilloscope probes ? I was guessing their length is important so they are fixed. GW Instek is all I have.
    I'm using TTL/CMOS output, it's not important which button is active (sin, tri, square), it produces 50% duty cycle square wave at 5V fixed (unless I pop duty cycle pot).
    How probes can be tuned ? I need help in here.
    It is rheostat. Yes it's a good source of EMI. Also it screams with high frequencies (seriously). It's surface is earthed. I can try moving it further.
    Bootstrap constrained by the need of bootstrap capacitor refresh. It makes direct converter more complex.
    Measurement taken at the SAAR collector and Neutral (Vout point in schematics)
    n channel igbt and common emitter causes 180degree phase shift.
    I was planning to build clamp circuit later but as you point out the bleeding wound I guess I need it quicker. Thank you. I'll be on this ne
    This is the gate driver supply schematic. Do you advice me to lower the capacitor values ?
    Do you advice me to use one of these ?
    https://www.mornsun-power.com/uploads/pdf/QAUxx.pdf
    Cake is a lie
  8. #8
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,203
    100
    No. I referred to the isolation capacitance, e.g. the transformer interwinding capacitance. The linear voltage regulator circuit is O.K. But it's not so good to have the power supply and transformer 1 m apart from the gate driver circuit. You create large antennas radiating switching noise.
    Do you mind to mark the connection of both probes in your circuit? I still can't relate your description to the shown waveforms.
  9. #9
    Antor's Avatar
    Mar 2019
    51
    314
    15V supply enclosures are metal and well earthed. I have to use long cables for first prototype. Do you advice me to use twisted pair cables ? Shielded cables ? Ferrite Choker ?
    Oscilloscope earthing is isolated. Another terms, oscilloscope has no earthing for some reasons.
    This slope exists if DC Supply current is under 1A and 30V
Name:	003- 1A 24.2V_LI.jpg
    Disappears if DC supply current is over 1A and 30V (1.33A and 31.7V at this measurement)
    I'm using DC source for converter for testing at the moment. Triggering only SAAF, It should act as DC chopper for now.
    Cake is a lie
  10. #10
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,203
    100
    How can you measure with different ground connection for blue and yellow trace simultaneously? The real circuit must be somehow different.
    Disconnecting the oscilloscope's protective earth wire in mains connection doesn't provide good isolation. Besides safety issues, there's still a considerable capacitive load between probe ground and earth affecting the measurement signals.
  11. #11
    Antor's Avatar
    Mar 2019
    51
    314
    Yes they are different grounds, It is just ment to observe overall. Trigger is on CH1 and it's on the load which I want to observe best. Disconnecting blue signal doesn't effect yellow. Still same.
    What is your suggestion about this issue ?
    I'm more worried about the slope between rise and fall. Why there is a slope ? Why it decreases while current increasing ?
    Cake is a lie
  12. #12
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,203
    100
    Besides unsuitable probe connection it may be dropping DC supply. I won't care about it much. Overshoot is much more a problem. It probably kills the IGBTs if you connect high input voltage.
    To measure voltages with arbitrary ground reference, a differential probe is the preferred solution.
  13. #13
    Aug 2016
    507
    2,884
    12
    That rheostat must be a very large one. It must be having significant inductance and switching its current abruptly like that might be causing the spike across the SAAF IGBT. Do you mind comnecting a snubber across it?
    How probes can be tuned?
    You just connect the oscilloscope probe BNC end to a channel on your scope and then connect clip end to the trigger output (two metal connection points) of your scope as if to measure the trigger signal. When you are done with the connection, you adjust the pot on the scope probe until you get a nice square waveform on the scope display.
    Quote Originally Posted by Antor View Post
    Why powering the driver with a supply not isolated from the mains? You should consider using channel 4 of your bench power supply to power it. That way you would be free from mains supply and multiple earthing connections and possible ground loop.
    By bad condition cables, what do you mean?
    What is GNDGRID referring to in your schematic of Post #1?
    NOTE!!!
    All the things I have suggested are for the DC testing only. You would have to analyze the risks before you carry out the AC testing.
    WARNING!!!
    Do not attempt these measurements if you are not sure what you are doing. Oscilloscope measurements on mains powered circuits are a major safety concern.
    --Akanimo.
  14. #14
    Antor's Avatar
    Mar 2019
    51
    314
    Rheostat is a simple one, 100ohm total, 250Watt. Snubber is not an option at this point. If those overshoots are not a measurement error, I'll try varistor to oppress/suppress (I couldn't decide which one is suitable) or try a clamp like below.
    I really don't believe that our cheap probes have a pot but I'll check tomorrow. I'm considering to buy differential probes as FvM suggested
    Schematics doesn't show but it's isolated with a transformer. AC IN 151 means terminals of seconder coil 1 (independent from other 2.3...).
    If you are telling me to use gw instek power supply unit, I don't believe in that power supply channel's are totally isolated. (Channels are in independent mode - series or parallel modes inactive).
    I have only 1 earthing connection and it's grid's earth (building's earth). I couldn't understand "ground loop".
    Earthing cable, it's not a good cable but It does the job. It consist of multiple cables added to each other. That's what I ment with bad condition.
    When inputs are AC 3Phase, GNDGRID means grid neutral. For testing it's DC supply 0/neutral.
    I'll consider this advice and use a variac/autotransformer and test AC with 1/4 of grid voltage.
    I'm behind a few fuses, circuit breakers and leakage current protection relays (I'm not sure if the last one is translated correctly). Also I'm keeping a 1kg small fire extinguisher.
    Thanks for all.
    Cake is a lie
  15. #15
    Aug 2015
    1,806
    11,060
    25
    You really need a scope with properly isolated inputs - to measure things in your circuit - having too many ground connections at the same or different points can make it very hard to measure true currents - draw out you circuit very carefully to make sure what you build corresponds exactly with what you want ...
  16. #16
    Aug 2016
    507
    2,884
    12
    The earthing cable should be a solid copper conductor of a certain cross-sectional area. You know it already. You're just ignoring it.
    Even when you have a differential probe, you still have be able to tune your conventional oscilloscope probes to display correct waveforms when you are using them. You see that round stainless steel on the scope probe that looks like the head of a screw, that's where you adjust for the nice square wave I talked about earlier on.
    --Akanimo.
  17. #17
    Antor's Avatar
    Mar 2019
    51
    314
    I have been suspecting why there is a little screwdriver in probe packs. Now it's clear =) I'm heading to my workshop. Thanks a lot.
    Update : There is screwdriver but no screw =( Rest of the probe is a whole piece that I can't apart.
ID:	155547Click image for larger version.
    Cake is a lie
  18. #18
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,203
    100
    Adjustment is either at the probe or the probe connector. Why don't you read the manual?
  19. #19
    Antor's Avatar
    Mar 2019
    51
    314
    Probe connector is a simple BNC connector. There is no screw. I borrowed probes from a friend and yes they had a screw to calibrate. I calibrated the proble with test signal on oscilloscope. Nice sharp squares.
    =Probe calibration check
    =Using shielded short cables for gate driver source check
    =Measured from the pins of the PCB check (no cables around)
    =Load metalic surfice earthed
    =Circuit board earthed
    Problem is overshoot stil exists.
    I didn't isolated heat sinks from IGBT, I used thermal paste for better cooling. Would it be overshoot problem ?
    Cake is a lie
  20. #20
    Aug 2016
    507
    2,884
    12
    Thermal paste conducts heat. They do not conduct electricity. In fact, it acts like a dielectric with the IGBT and the heatsink acting like the two parallel plates of a capacitor, the thermal paste sandwiched between them. If the heatsink is connected to earth, then the setup produces common-mode noise when switched rapidly.
    Single-ended oscilloscopes like the ones we find everywhere can pick up this noise.
    If your scope was picking up common mode noise, I believe the noise would be at a much higher frequency.
    --Akanimo.
