tapu
Full Member level 4
Dear All,
I am making a clock of dual display one 4 digit 7 segment display and Lcd(16x2) by using 89s52.both should show time(as my application).I am using multiplexing method in displaying data on led display.Lcd display running successfully but led display shows on-off continously.Here is my code.
video shoot of proteus simulator
but same problen seen on actual hardware.
#include <REGX51.H>
sbit set=P1^0;
sbit mov=P1^1;
sbit inc=P1^2;
sbit dec=P1^3;
sbit rly=P1^4;
sbit digi1=P1^5;//3rd e5
sbit digi4=P2^3;//4th e6
sbit blink=P2^1;
sbit bus=P3^7;
sbit ind=P3^6;
sbit digi3=P1^7;//1st e4
sbit digi2=P1^6;//2nd e3
sbit SDA=P2^6;
sbit SCL=P2^7;
bit d;
bit e;
bit f;
bit nxt;
bit nxta;
unsigned char dec_hex(unsigned char tt)
if(tt>59)
tt+=36;
else if(tt>49)
tt+=30;
else if(tt>39)
tt+=24;
else if(tt>29)
tt+=18;
else if(tt>19)
tt+=12;
else if(tt>9)
tt+=6;
return(tt);
display_digit();
void all_disp();
void time_set();
void alarm_set();
void set_date();
void blink_on();
void buzzer();
void no_op();
void setdisp_ampm();
void alarm_setsat();
unsigned int zt;
unsigned char led_data;
void alarm_bell_HI();
void alarm_bell_LOW();
void display_day();
void puls();
void no_puls();
#define First_Line 0x80
#define Second_Line 0xc0
#define Curser_On 0x0f
#define Curser_Off 0x0c
#define Clear_Display 0x01
#define idle f==1
#define no_idle f==0
#define Data_Port P0
sbit Lcd_rs = P2^0;
//sbit Lcd_rw = P2^1;
sbit Lcd_en = P2^2;
sbit sda_rtc =P2^5;
sbit scl_rtc =P2^4;
/*sbit Lcd_rs = P3^5;
sbit Lcd_rw = P3^6;
sbit Lcd_en = P3^7; */
void Lcd8_Init();
void Lcd8_Command(unsigned char);
void Lcd8_Write(unsigned char,unsigned char);
void Lcd8_Display(unsigned char,const unsigned char*,unsigned int);
void Lcd8_decimal2(unsigned char,unsigned char val);
void Delay(unsigned int);
void del();
void hour_mode();
void set_mod1();
void set_mod2();
unsigned char LB,SB;
void Seg8_decimal2(min);
void Led8decimal2(hour);
unsigned char num;
void EEPROM_WriteByte(unsigned char eeprom_Address, unsigned char eeprom_Data);
unsigned char EEPROM_ReadByte(unsigned char eeprom_Address);
void I2C_Start();
void I2C_Stop(void);
void I2C_Ack();
void I2C_Write(unsigned char dat);
unsigned char I2C_Read();
#define EEPROM_ID 0xa0
void delay_ms(unsigned int ms_count);
void I2C_NoAck();
void I2C_Clock();
void delay_us(unsigned int us_count);
void msdelay(unsigned int value);
void emerg_bell();
void display_ampm1();
void display_ampm2();
//unsigned char number[]="1,2,3,4";
#define DS1307_ID 0xD0
#define SEC 0x00
#define MIN 0x01
#define HOUR 0x02
#define DAY 0x03
#define DATE 0x04
#define MONTH 0x05
#define YEAR 0x06
#define ctrl 0x07
#define FRIDAY 0x06
#define SATURDAY 0x00
#define SUNDAY 0x01
DS1307_get(unsigned char);
void DS1307_settime(unsigned char, unsigned char, unsigned char);
void DS1307_setdate(unsigned char, unsigned char, unsigned char,unsigned char);
Send2lcd(unsigned char);
void Rtc_Write(unsigned char,unsigned char);
Rtc_Read(unsigned char);
void Rtc_rd_wr_sub();
void Rtc_Init();
void Rtc_Start();
void Rtc_Tx();
void Rtc_Rx();
void Rtc_Stop();
void Rtc_Ack();
void disp();
void disp_time();
void display_ampm();
void dispampm();
void set_ampm();
void set_mod();
void alarm_chk1();
void alarm_chk2();
void alarm_chk3();
void alarm_chk4();
void all_alrmset();
void all_alrmsetsat();
void friday_chk();
void regular_chk();
void saturday_chk();
void idle_chk();
void no_idle_chk();
void key_lock2();
unsigned int Rtc_add_wr,Rtc_add_rd;
unsigned char d_rtc,datain_rtc,in_rtc,temp_rtc,dat_rtc,flag_rtc;
unsigned char i,j,a[10],cur=0,cur1=0,cur2=0,cur3=0,cur4=0;
unsigned char dati,sec,hour,min,date,day,month,year,mode=0,clk_a mpm,sec1,hour1,min1,sec2,hour2,min2,hh,mm,ss,dd,mn ,yy,ahour,amin,ampm,asec,amin1,ahour1,ampm1;
unsigned char count[8]={0x82,0x85,0x8a,0x8d,0xc2,0xc5,0xcb,0xcd}; ///0x8a changed
code unsigned char memo[66]={0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x1 0,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x2 0,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x3 0,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x2a,0x2 b,0x2c,0x2d,0x2e,0x2f,0x3a,0x3b,0x3c,0x3d,0x3e,0x3 f,0x1a,0x1b,0x1c,0x1d,0x1e,0x1f,0xa,0xb,0xc,0xd,0x e,0xf,0x39,0x40,0x4a,0x4b};
code unsigned char memo1[66]={0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x50,0x5 1,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x60,0x6 1,0x62,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x70,0x7 1,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x5a,0x5 b,0x5c,0x5d,0x5e,0x5f,0x6a,0x6b,0x6c,0x6d,0x6e,0x6 f,0x7a,0x7b,0x7c,0x7d,0x7e,0x7f,0x8a,0x8b,0x8c,0x8 d,0x8e,0x8f,0x9a,0x9b,0x9c,0x9d};
unsigned char count1[6]={0x86,0x89,0x8b,0xc6,0xc9,0xcb};
unsigned char count2[2]={0x8b,0xcb};
unsigned char rly_hex(unsigned char tt)
if(tt>59)
tt+=36;
else if(tt>49)
tt+=30;
else if(tt>39)
tt+=24;
else if(tt>29)
tt+=18;
else if(tt>19)
tt+=12;
else if(tt>9)
tt+=6;
return(tt);
void all_disp()
sec = DS1307_get(SEC);
min = DS1307_get(MIN);
hour = DS1307_get(HOUR);
dispampm();
setdisp_ampm();
hour=hour& 0x1f;
display_ampm();
date = DS1307_get(DATE);
day = DS1307_get(DAY);
month = DS1307_get(MONTH);
year = DS1307_get(YEAR);
sec=Send2lcd(sec);
min=Send2lcd(min);
hour=Send2lcd(hour);
day=Send2lcd(day);
date=Send2lcd(date);
year=Send2lcd(year);
month=Send2lcd(month);
//P3=day;
Lcd8_decimal2(0xc6,hour);
Lcd8_Write(0xc8,'.');
Lcd8_decimal2(0xc9,min);
Lcd8_Write(0xcb,'.');
Lcd8_decimal2(0xcc,sec);
Lcd8_decimal2(0x82,date);
Lcd8_Write(0x84,'-');
Lcd8_decimal2(0x85,month);
Lcd8_Write(0x87,'-');
Lcd8_Display(0x88,"20 ",2);
Lcd8_decimal2(0x8a,year);
//Lcd8_decimal2(0x8d,day);
Seg8_decimal2(min);//.................................................. .................................................. ...............
Led8decimal2(hour);//.................................................. .................................................
void main()
nxt=0;
rly=0;
dati=0x00;
Lcd8_Init();
Lcd8_Display(0x82,"ZAKARIYA ",8);
Lcd8_Display(0xc3,"Technologies ",12);
Delay(65000);
Delay(65000);
Lcd8_Command(0x01);
Rtc_Init();
//puls();
//DS1307_setdate(0x04,0x11,0x11);
//DS1307_settime(0x16,0x00,0x00);
while(1)
//P1=EEPROM_ReadByte(memo[1]);
dati++;
all_disp();
Rtc_Start();
Rtc_Write(0x07,0x10);
Rtc_Stop(); /* Stop i2c bus */
//disp();
display_day();
//no_idle_chk();if(no_idle) goto straight; //No alarm betwen 8pm to 6am
//idle_chk();if(idle) goto jump; //No alarm betwen 8pm to 6am
//if(day==SATURDAY) goto jump;
if(day==0x01) goto jump;
//if(day==FRIDAY)
//friday_chk();
//else
if(day==0x07)
saturday_chk();
else
straight:
regular_chk();
jump:
if(!set)
key_lock2(); ///show as keypad locked(when press set/inc/dec)
if(!inc)
if(!dec)
if(!dec)
alarm_bell_HI();
if(!set)
alarm_bell_LOW();
if(mov==0)
Delay(65000);
Delay(65000);
Delay(65000);
if(mov==0)
Lcd8_Command(0x01);
Lcd8_Display(0xc4,"Unlocked ",8);
Delay(65000);
time_set();
cur2=0;
cur4=0;
Lcd8_Command(0x01);
Lcd8_Command(0x0c);
Lcd8_Display(0x82,"REGULAR ",7);
Lcd8_Display(0xC4,"SCHEDULE ",8);
Delay(65000);
Delay(65000);
all_alrmset();
Lcd8_Command(0x01);
Lcd8_Display(0x82,"SATURDAY",8);
Delay(65000);
Delay(65000);
all_alrmsetsat();
set_date();
if(dati==0x03)
blink=~blink;
dati=0x00;
void dispampm()
if(hour==0x00)
d=0;
clk_ampm=0;
Rtc_Start();
Rtc_Write(0x02,0x40);
if(hour==0x01)
d=0;
clk_ampm=0;
Rtc_Start();
Rtc_Write(0x02,0x41);
if(hour==0x02)
d=0;
clk_ampm=0;
Rtc_Start();
Rtc_Write(0x02,0x42);
if(hour==0x03)
d=0;
clk_ampm=0;
Rtc_Start();
Rtc_Write(0x02,0x43);
if(hour==0x04)
d=0;
clk_ampm=0;
Rtc_Start();
Rtc_Write(0x02,0x44);
if(hour==0x05)
d=0;
clk_ampm=0;
Rtc_Start();
Rtc_Write(0x02,0x45);
if(hour==0x06)
d=0;
clk_ampm=0;
Rtc_Start();
Rtc_Write(0x02,0x46);
if(hour==0x07)
d=0;
clk_ampm=0;
Rtc_Start();
Rtc_Write(0x02,0x47);
if(hour==0x08)
d=0;
clk_ampm=0;
Rtc_Start();
Rtc_Write(0x02,0x48);
if(hour==0x09)
d=0;
clk_ampm=0;
Rtc_Start();
Rtc_Write(0x02,0x49);
if(hour==0x10)
d=0;
clk_ampm=0;
Rtc_Start();
Rtc_Write(0x02,0x4a);
if(hour==0x11)
d=0;
clk_ampm=0;
Rtc_Start();
Rtc_Write(0x02,0x4b);
if(hour==0x12)
d=1;
clk_ampm=1;
Rtc_Start();
Rtc_Write(0x02,0x72);
if(hour==0x13)
d=1;
clk_ampm=1;
Rtc_Start();
Rtc_Write(0x02,0x61);
if(hour==0x14)
d=1;
clk_ampm=1;
Rtc_Start();
Rtc_Write(0x02,0x62);
if(hour==0x15)
d=1;
clk_ampm=1;
Rtc_Start();
Rtc_Write(0x02,0x63);
if(hour==0x16)
d=1;
clk_ampm=1;
Rtc_Start();
Rtc_Write(0x02,0x64);
if(hour==0x17)
d=1;
clk_ampm=1;
Rtc_Start();
Rtc_Write(0x02,0x65);
if(hour==0x18)
d=1;
clk_ampm=1;
Rtc_Start();
Rtc_Write(0x02,0x66);
if(hour==0x19)
d=1;
clk_ampm=1;
Rtc_Start();
Rtc_Write(0x02,0x67);
if(hour==0x20)
d=1;
clk_ampm=1;
Rtc_Start();
Rtc_Write(0x02,0x68);
if(hour==0x21)
d=1;
clk_ampm=1;
Rtc_Start();
Rtc_Write(0x02,0x69);
if(hour==0x22)
d=1;
clk_ampm=1;
Rtc_Start();
Rtc_Write(0x02,0x6a);
if(hour==0x23)
d=1;
clk_ampm=1;
Rtc_Start();
Rtc_Write(0x02,0x6b);
void key_lock2()
Lcd8_Command(0x01);
Lcd8_Display(0xc1,"Keypad locked ",13);
Delay(65000);
Lcd8_Command(0x01);
void idle_chk()
if(hour==7)
if(d==1)
f=1;
if(hour==8)
if(d==1)
f=1;
if(hour==9)
if(d==1)
f=1;
if(hour==10)
if(d==1)
f=1;
if(hour==11)
if(d==1)
f=1;
if(hour==12)
if(d==0)
f=1;
if(hour==1)
if(d==0)
f=1;
if(hour==2)
if(d==0)
f=1;
if(hour==3)
if(d==0)
f=1;
if(hour==4)
if(d==0)
f=1;
if(hour==5)
if(d==0)
f=1;
if(hour==6)
if(d==0)
f=1;
void no_idle_chk()
if(hour==7)
if(d==0)
f=0;
if(hour==8)
if(d==0)
f=0;
if(hour==9)
if(d==0)
f=0;
if(hour==10)
if(d==0)
f=0;
if(hour==11)
if(d==0)
f=0;
if(hour==12)
if(d==1)
f=0;
if(hour==1)
if(d==1)
f=0;
if(hour==2)
if(d==1)
f=0;
if(hour==3)
if(d==1)
f=0;
if(hour==4)
if(d==1)
f=0;
if(hour==5)
if(d==1)
f=0;
if(hour==6)
if(d==1)
f=0;
void all_alrmset(void)
nxt=0;
up:alarm_set();
//alarm_setsat();
if(nxt==0) goto up;
void all_alrmsetsat(void)
nxta=0;
up:alarm_setsat();
if(nxta==0) goto up;
void friday_chk()
void regular_chk()
alarm_chk1();
alarm_chk2();
void saturday_chk()
alarm_chk3();
alarm_chk4();
void setdisp_ampm()
if(hour==0x52)
d=0;
clk_ampm=00;
if(hour==0x41)
d=0;
clk_ampm=00;
if(hour==0x42)
d=0;
clk_ampm=00;
if(hour==0x43)
d=0;
clk_ampm=00;
if(hour==0x44)
d=0;
clk_ampm=00;
if(hour==0x45)
d=0;
clk_ampm=00;
if(hour==0x46)
d=0;
clk_ampm=00;
if(hour==0x47)
d=0;
clk_ampm=00;
if(hour==0x48)
d=0;
clk_ampm=00;
if(hour==0x49)
d=0;
clk_ampm=00;
if(hour==0x4a)
d=0;
clk_ampm=00;
if(hour==0x4b)
d=0;
clk_ampm=00;
if(hour==0x72)
d=1;
clk_ampm=01;
if(hour==0x61)
d=1;
clk_ampm=01;
if(hour==0x62)
d=1;
clk_ampm=01;
if(hour==0x63)
d=1;
clk_ampm=01;
if(hour==0x64)
d=1;
clk_ampm=01;
if(hour==0x65)
d=1;
clk_ampm=01;
if(hour==0x66)
d=1;
clk_ampm=01;
if(hour==0x67)
d=1;
clk_ampm=01;
if(hour==0x68)
d=1;
clk_ampm=01;
if(hour==0x69)
d=1;
clk_ampm=01;
if(hour==0x6a)
d=1;
clk_ampm=01;
if(hour==0x6b)
d=1;
clk_ampm=01;
void disp_time()
hour=hour& 0x1f;
sec=Send2lcd(sec);
min=Send2lcd(min);
Lcd8_decimal2(0xc2,hour);
Lcd8_Write(0xc4,'.');
Lcd8_decimal2(0xc5,min);
Lcd8_Write(0xc7,'.');
Lcd8_decimal2(0xc8,sec);
set_ampm();
Seg8_decimal2(min);
Led8decimal2(hour);
void display_ampm()
if(d==0)
Lcd8_Display(0xce,"AM ",2);/////////////////////////////////////////////////////////changed
if(d==1)
Lcd8_Display(0xce,"PM ",2);/////////////////////////////////////////////////////////changed
if(d==0)
Lcd8_Display(0x8b,"AM ",2);/////////////////////////////////////////////////////////changed
if(d==1)
Lcd8_Display(0x8b,"PM ",2);/////////////////////////////////////////////////////////changed
if(d==0)
Lcd8_Display(0xcb,"AM ",2);/////////////////////////////////////////////////////////changed
if(d==1)
Lcd8_Display(0xcb,"PM ",2);/////////////////////////////////////////////////////////changed
void set_ampm()
if(d==0)
clk_ampm=00;
if(d==1)
clk_ampm=01;
void emerg_bell()
void no_op()
void hour_mode()
if(hour>12)
hour=hour-12;
void puls()
Rtc_Start();
Rtc_Write(0x07,0x10); /* Write date on RAM address 04H */
void no_puls()
Rtc_Start();
Rtc_Write(0x07,0x00); /* Write date on RAM address 04H */
void display_day()
if(day==0x01)
Lcd8_Display(0xc1,"SUN ",3);
if(day==0x02)
Lcd8_Display(0xc1,"MON ",3);
if(day==0x03)
Lcd8_Display(0xc1,"TUE ",3);
if(day==0x04)
Lcd8_Display(0xc1,"WED ",3);
if(day==0x05)
Lcd8_Display(0xc1,"THU ",3);
if(day==0x06)
Lcd8_Display(0xc1,"FRI ",3);
if(day==0x07)
Lcd8_Display(0xc1,"SAT ",3);
void set_date()
blink_on();
Lcd8_Command(0x01);
all_disp();
cur=0;
while(set)
Lcd8_Command(0x0f);
Lcd8_Command(count[cur]);
if(mov==0)
while(!mov);
cur++;
blink_on();
if(cur==4)
cur=0;
else if(count[cur]==0x82)
if(inc==0)
while(inc==0);
date++;
blink_on();
Lcd8_decimal2(count[cur],date);
if(date>31)
date=0;
else if(dec==0)
while(!dec);
date--;
blink_on();
if(date==0xff)
date=99;
else if(count[cur]==0x85)
if(inc==0)
while(inc==0);
month++;
blink_on();
Lcd8_decimal2(count[cur],month);
if(month>12)
month=0;
else if(dec==0)
while(!dec);
month--;
blink_on();
if(month==0xff)
month=99;
else if(count[cur]==0x8a)
if(inc==0)
while(!inc);
year++;
blink_on();
Lcd8_decimal2(count[cur],year);
if(year>99)
year=0;
else if(dec==0)
while(!dec);
year--;
blink_on();
if(year==0xff)
year=99;
else if(count[cur]==0x8d)
if(inc==0)
while(!inc);
day++;
blink_on();
//Lcd8_Command(0x01);
display_day();
Lcd8_decimal2(count[cur],day);
if(day>6)
day=0;
else if(dec==0)
while(!dec);
day--;
blink_on();
display_day();
if(day==0xff)
day=7;
dd=dec_hex(date);
mn=dec_hex(month);
yy=dec_hex(year);
day=dec_hex(day);
DS1307_setdate(dd,mn,yy,day);
Lcd8_Command(0x0c);
puls();
void blink_on()
blink=0;
Delay(6500);
blink=1;
void set_mod()
if(mode==1)
d=0;
clk_ampm=00;
if(mode==2)
d=1;
clk_ampm=01;
void set_mod1()
if(mode==1)
d=0;
//hour=hour-12;
if(mode==2)
d=1;
//hour=hour+12;
void set_mod2()
if(mode==1)
d=0;
//hour=hour-12;
if(mode==2)
d=1;
//hour=hour+12;
void time_set()
blink_on();
Lcd8_Command(Curser_On);
Lcd8_Command(0x01);
Lcd8_Display(0x84,"Set Time",8);
disp_time();
cur=4;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
blink_on();
if(cur==7)
cur=4;
else if(count[cur]==0xc2)
if(inc==0)
while(inc==0);
hour++;
blink_on();
Led8decimal2(hour);
if(hour>12)
hour=0;
else if(dec==0)
while(!dec);
hour--;
blink_on();
Led8decimal2(hour);
if(hour==0)
hour=12;
else if(count[cur]==0xc5)
if(inc==0)
while(inc==0);
min++;
blink_on();
Seg8_decimal2(min);
if(min>=60)
min=0;
else if(dec==0)
while(!dec);
min--;
blink_on();
Seg8_decimal2(min);
if(min==0xff)
min=31;
else if(count[cur]==0xcb)
if(inc==0)
while(!inc);
mode++;
set_mod();
Delay(6500);
blink_on();
//display_ampm();
if(mode>1)
mode=0;
hh=rly_hex(hour);
mm=rly_hex(min);
if(d==1)
hh= hh | 0x60;
if(d==0)
hh= hh | 0x40;
DS1307_settime(hh,mm,ss);
void buzzer()
//e4=0;
//e3=0;
//P3=0xff;
//e4=1;
//e3=1;
// Delay(6500);
//Led8decimal2(hour);
void alarm_setsat()
no_puls();
cur4++;
ahour=EEPROM_ReadByte(memo1[cur4]);
cur4++;
amin=EEPROM_ReadByte(memo1[cur4]);
cur4++;
ampm=EEPROM_ReadByte(memo1[cur4]);
cur4++;
ahour1=EEPROM_ReadByte(memo1[cur4]);
cur4++;
amin1=EEPROM_ReadByte(memo1[cur4]);
cur4++;
ampm1=EEPROM_ReadByte(memo1[cur4]);
Delay(10000);
blink_on();
Lcd8_Command(Curser_Off);
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
Lcd8_Display(0x88,":",1);
Lcd8_Display(0xc8,":",1);
if(cur4<25)
Lcd8_Display(0x82,"LB)",3);
Lcd8_decimal2(0x86,ahour);
Lcd8_decimal2(0x89,amin);
Lcd8_decimal2(0x8b,ampm);
if(ampm==0)
d=0;
display_ampm1();
if(ampm==1)
d=1;
display_ampm1();
Lcd8_Display(0xc2,"LB)",3);
Lcd8_decimal2(0xc6,ahour1);
Lcd8_decimal2(0xc9,amin1);
Lcd8_decimal2(0xcb,ampm1);
if(ampm1==0)
d=0;
display_ampm2();
if(ampm1==1)
d=1;
display_ampm2();
else
Lcd8_Display(0x82,"SB)",3);
if(ampm==0)
d=0;
display_ampm1();
if(ampm==1)
d=1;
display_ampm1();
Lcd8_Display(0xc2,"SB)",3);
if(ampm1==0)
d=0;
display_ampm2();
if(ampm1==1)
d=1;
display_ampm2();
cur1=0;
while(set)
Lcd8_Command(0x0f);
Lcd8_Command(count1[cur1]);
if(mov==0)
while(!mov);
cur1++;
if(cur1==6)
cur1=0;
else if(count1[cur1]==0x86) ///1st line of lcd
if(inc==0)
while(inc==0);
ahour++;
blink_on();
if(ahour>=13)
ahour=0;
Lcd8_decimal2(count1[cur1],ahour);
else if(dec==0)
while(!dec);
ahour--;
blink_on();
if(ahour==0)
ahour=12;
else if(count1[cur1]==0x89)
if(inc==0)
while(inc==0);
amin++;
blink_on();
if(amin>=60)
amin=0;
Lcd8_decimal2(count1[cur1],amin);
else if(dec==0)
while(!dec);
amin--;
blink_on();
if(amin==0)
amin=59;
else if(count1[cur1]==0x8b)
if(inc==0)
while(inc==0);
ampm=0;
d=0;
display_ampm1();
blink_on();
if(ampm>1)
ampm=0;
//Lcd8_decimal2(count1[cur1],ampm);
else if(dec==0)
while(!dec);
ampm=1;
d=1;
display_ampm1();
blink_on();
else if(count1[cur1]==0xc6)
if(inc==0)
while(inc==0);
ahour1++;
blink_on();
if(ahour1>=13)
ahour1=0;
Lcd8_decimal2(count1[cur1],ahour1);
else if(dec==0)
while(!dec);
ahour1--;
blink_on();
if(ahour1==0)
ahour1=12;
else if(count1[cur1]==0xc9)
if(inc==0)
while(inc==0);
amin1++;
blink_on();
if(amin1>=60)
amin1=0;
Lcd8_decimal2(count1[cur1],amin1);
else if(dec==0)
while(!dec);
amin1--;
blink_on();
if(amin1==0)
amin1=60;
else if(count1[cur1]==0xcb)
if(inc==0)
while(inc==0);
ampm1=0;
d=0;
display_ampm2();
blink_on();
//Lcd8_decimal2(count1[cur1],ampm1);
else if(dec==0)
while(!dec);
ampm1=1;
d=1;
display_ampm2();
blink_on();
Lcd8_Command(0x0c);
//Delay(65000);Delay(65000);
cur4--;
cur4--;
cur4--;
cur4--;
cur4--;
EEPROM_WriteByte(memo1[cur4], ahour);
cur4++;
EEPROM_WriteByte(memo1[cur4], amin);
cur4++;
EEPROM_WriteByte(memo1[cur4], ampm);
cur4++;
EEPROM_WriteByte(memo1[cur4], ahour1);
cur4++;
EEPROM_WriteByte(memo1[cur4], amin1);
cur4++;
EEPROM_WriteByte(memo1[cur4], ampm1);
Lcd8_Command(0x01);
if(cur4==66)
nxta=1;
void alarm_set()
no_puls();
cur2++;
ahour=EEPROM_ReadByte(memo[cur2]);
cur2++;
amin=EEPROM_ReadByte(memo[cur2]);
cur2++;
ampm=EEPROM_ReadByte(memo[cur2]);
cur2++;
ahour1=EEPROM_ReadByte(memo[cur2]);
cur2++;
amin1=EEPROM_ReadByte(memo[cur2]);
cur2++;
ampm1=EEPROM_ReadByte(memo[cur2]);
Delay(10000);
blink_on();
Lcd8_Command(0x0f);
Lcd8_Command(0x01);
if(cur2<25)
if(ampm==0)
d=0;
display_ampm1();
if(ampm==1)
d=1;
display_ampm1();
if(ampm1==0)
d=0;
display_ampm2();
if(ampm1==1)
d=1;
display_ampm2();
else
if(ampm==0)
d=0;
display_ampm1();
if(ampm==1)
d=1;
display_ampm1();
if(ampm1==0)
d=0;
display_ampm2();
if(ampm1==1)
d=1;
display_ampm2();
cur1=0;
while(set)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur1++;
if(cur1==6)
cur1=0;
if(inc==0)
while(inc==0);
ahour++;
blink_on();
if(ahour>=13)
ahour=0;
else if(dec==0)
while(!dec);
ahour--;
blink_on();
if(ahour==0)
ahour=12;
if(inc==0)
while(inc==0);
amin++;
blink_on();
if(amin>=60)
amin=0;
else if(dec==0)
while(!dec);
amin--;
blink_on();
if(amin==0)
amin=59;
if(inc==0)
while(inc==0);
ampm=0;
d=0;
display_ampm1();
blink_on();
if(ampm>1)
ampm=0;
else if(dec==0)
while(!dec);
ampm=1;
d=1;
display_ampm1();
blink_on();
if(inc==0)
while(inc==0);
ahour1++;
blink_on();
if(ahour1>=13)
ahour1=0;
else if(dec==0)
while(!dec);
ahour1--;
blink_on();
if(ahour1==0)
ahour1=12;
if(inc==0)
while(inc==0);
amin1++;
blink_on();
if(amin1>=60)
amin1=0;
else if(dec==0)
while(!dec);
amin1--;
blink_on();
if(amin1==0)
amin1=60;
if(inc==0)
while(inc==0);
ampm1=0;
d=0;
display_ampm2();
blink_on();
else if(dec==0)
while(!dec);
ampm1=1;
d=1;
display_ampm2();
blink_on();
Lcd8_Command(0x0c);
cur2--;
cur2--;
cur2--;
cur2--;
cur2--;
EEPROM_WriteByte(memo[cur2], ahour);
cur2++;
EEPROM_WriteByte(memo[cur2], amin);
cur2++;
EEPROM_WriteByte(memo[cur2], ampm);
cur2++;
EEPROM_WriteByte(memo[cur2], ahour1);
cur2++;
EEPROM_WriteByte(memo[cur2], amin1);
cur2++;
EEPROM_WriteByte(memo[cur2], ampm1);
Lcd8_Command(0x01);
if(cur2==66)
nxt=1;
void alarm_chk1()
for(cur2=1;cur2<25;cur2++)
cur2++;
cur2++;
asec=00;
if(hour==ahour)
if(min==amin)
if(sec==asec)
if(clk_ampm==ampm)
alarm_bell_HI();
else
rly=0;
void alarm_chk2()
for(cur2=25;cur2<67;cur2++)
cur2++;
cur2++;
asec=00;
if(hour==ahour)
if(min==amin)
if(sec==asec)
if(clk_ampm==ampm)
alarm_bell_LOW();
else
rly=0;
void alarm_chk3()
for(cur4=1;cur4<25;cur4++)
cur4++;
cur4++;
asec=00;
if(hour==ahour)
if(min==amin)
if(sec==asec)
if(clk_ampm==ampm)
alarm_bell_HI();
else
rly=0;
void alarm_chk4()
for(cur4=25;cur4<67;cur4++)
cur4++;
cur4++;
asec=00;
if(hour==ahour)
if(min==amin)
if(sec==asec)
if(clk_ampm==ampm)
alarm_bell_LOW();
else
rly=0;
Lcd8_Command(0x01);
Lcd8_Display(0xc0,"Bell ringing.. ",14);
rly=1;
delay_ms(12000);
rly=0;
Delay(65000);
Delay(65000);
Lcd8_Command(0x01);
Lcd8_Command(0x01);
rly=1;
delay_ms(6000);
rly=0;
Delay(65000);
Delay(65000);
Lcd8_Command(0x01);
void Lcd8_Init()
Lcd8_Command(0x38); //to select function set
Lcd8_Command(0x06); //entry mode set
Lcd8_Command(0x0c); //display on
Lcd8_Command(0x01); //clear display
void Lcd8_Command(unsigned char com)
Data_Port=com;
Lcd_en=1;
Lcd_rs=0;
//Lcd_rw=0;
Delay(125);
Lcd_en=0;
Delay(125);
void Lcd8_Write(unsigned char com,unsigned char lr)
Lcd8_Command(com);
Data_Port=lr; // Data
Lcd_en=Lcd_rs=1;
//Lcd_rw=0;
Delay(125);
Lcd_en=0;
Delay(125);
void Lcd8_Display(unsigned char com,const unsigned char *word,unsigned int n)
unsigned char Lcd_i;
for(Lcd_i=0;Lcd_i<n;Lcd_i++)
Lcd8_Write(com+Lcd_i,word[Lcd_i]);
void Lcd8_decimal2(unsigned char com,unsigned char val)
unsigned int Lcd_hr,Lcd_t,Lcd_o;
Lcd_hr=val%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
Lcd8_Write(com,Lcd_t+0x30);
Lcd8_Write(com+1,Lcd_o+0x30);
void Delay(unsigned int del)
while(del--);
Lcd_hr=min%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
led_data=Lcd_t+0x30;
display_digit();
digi3=1;
delay_ms(5);
digi3=0;
led_data=Lcd_o+0x30;
display_digit();
digi4=1;
delay_ms(5);
digi4=0;
Lcd_hr=hour%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
display_digit();
digi1=1;
delay_ms(5);
digi1=0;
display_digit();
digi2=1;
delay_ms(5);
digi2=0;
display_digit()
if(led_data==0x30)
P3=0x40;
//else
if(led_data==0x31)
P3=0xf9;
//else
if(led_data==0x32)
P3=0x24;
//else
if(led_data==0x33)
P3=0x30;
//else
if(led_data==0x34)
P3=0x99;
//else
if(led_data==0x35)
P3=0x92;
//else
if(led_data==0x36)
P3=0x82;
//else
if(led_data==0x37)
P3=0xf8;
//else
if(led_data==0x38)
P3=0x00;
//else
if(led_data==0x39)
P3=0x90;
/*********************************LCD HEADER FILE END*************************************/
/*********************************RTC HEADER FILE START*********************************/
DS1307_get(unsigned char addr)
unsigned char ret;
Rtc_Start();
ret = Rtc_Read(addr);
Rtc_Stop();
return ret;
void DS1307_settime(unsigned char hh, unsigned char mm, unsigned char ss)
Rtc_Start();
Rtc_Write(0x00,ss); /* Write sec on RAM address 00H */
Rtc_Write(0x01,mm); /* Write min on RAM address 01H */
Rtc_Write(0x02,hh); /* Write hour on RAM address 02H */
hh=hh& 0x1f;
void DS1307_setdate(unsigned char dd, unsigned char mm, unsigned char yy,unsigned char day)
Rtc_Start();
Rtc_Write(0x04,dd); /* Write date on RAM address 04H */
Rtc_Write(0x05,mm); /* Write month on RAM address 05H */
Rtc_Write(0x06,yy); /* Write year on RAM address 06H */
Rtc_Write(0x03,day); /* Write year on RAM address 03H */
Send2lcd(unsigned char value)
unsigned char buf1,buf2,buf = 0;
buf1 = value & 0xF0; /* Filter for high byte */
buf1 = (buf1>>4); /* Convert to ascii code */
buf2 = value & 0x0F; /* Filter for low byte */
buf=(buf1*10)+buf2;
return buf;
void Rtc_Init()//lower order 256 bytes of the chip
Rtc_add_wr=0xd0;
Rtc_add_rd=0xd1;
void Rtc_Write(unsigned char zig,unsigned char zag)// program to write to EEPROM
dat_rtc=zig;
temp_rtc=zag;
Rtc_rd_wr_sub();
above:
d_rtc=temp_rtc;
Rtc_Tx();
if (CY==1)goto above;
CY=0;
Rtc_Stop();
Rtc_Read(unsigned char zig)// program to read from EEPROM
dat_rtc=zig;
Rtc_rd_wr_sub();
Rtc_Start();
be:
d_rtc=Rtc_add_rd; // 0xd1 =Rtc_add_rd
Rtc_Tx();
if(CY==1)goto be;
Rtc_Rx();
Rtc_Ack();
CY=0;
Rtc_Stop();
return(datain_rtc);
void Rtc_Start()// must for any operation on EEPROM
sda_rtc=1;
scl_rtc=1;
sda_rtc=0;
scl_rtc=0;
void Rtc_Stop()// this is similar to the START operation whereas this should be performed after the completion of any operation
sda_rtc=0;
scl_rtc=1;
sda_rtc=1;
void Rtc_Tx()// program to send the device address, read/write address,data to be written
signed char i_rtc;
for(i_rtc=7;i_rtc>=0;i_rtc--)// should necessarily be initialised as signed char.
CY=(d_rtc>>i_rtc)&0x01;
sda_rtc=CY;
scl_rtc=1;// clock is essential inorder to write or read
scl_rtc=0;// clk should be alternated
sda_rtc=1;
scl_rtc=1;
CY=sda_rtc;
scl_rtc=0;
void Rtc_Rx()// program read the data from the EEPROM
unsigned char l_rtc;
sda_rtc=1;
for (l_rtc=0;l_rtc<=7;l_rtc++)
scl_rtc=1;
in_rtc=in_rtc<<1;
in_rtc|=sda_rtc;
scl_rtc=0;
datain_rtc=in_rtc;
in_rtc=0;
void Rtc_Ack()// this is to intimate the EEPROM that the read operation is over
sda_rtc=1;
scl_rtc=1;
scl_rtc=0;
void Rtc_rd_wr_sub()// this routine will be used by both the read & write operations to send the device address & the address at which the corresponding action is to be taken
Rtc_Start();
here1:
d_rtc=Rtc_add_wr;// 0xd0 device address is passed
Rtc_Tx();
if(CY==1)goto here1;
again1:
d_rtc=dat_rtc;// the address from which data is to be read/written is to be passed
Rtc_Tx();
if(CY==1)goto again1;
I2C_Start(); // Start i2c communication
I2C_Write(EEPROM_ID); // connect to AT2404 by sending its ID on I2c Bus
I2C_Ack();
I2C_Write(eeprom_Address); // Select the Specified EEPROM address of AT2404
I2C_Ack();
I2C_Write(eeprom_Data); // Write the data at specified address
I2C_Ack();
I2C_Stop(); // Stop i2c communication after Writing the data
delay_ms(1); // Write operation takes max 5ms, refer At2404 datasheet
unsigned char eeprom_Data;
I2C_Write(EEPROM_ID); // connect to AT2404(write) by sending its ID on I2c Bus
I2C_Ack();
I2C_Ack();
I2C_Write(0xA1); // connect to AT2404(read) by sending its ID on I2c Bus
I2C_Ack();
eeprom_Data = I2C_Read(); // Read the data from specified address
I2C_NoAck();
I2C_Stop(); // Stop i2c communication after Reading the data
delay_us(10);
return eeprom_Data; // Return the Read data
void I2C_Start()
SCL = 0; // Pull SCL low
SDA = 1; // Pull SDA High
delay_us(1);
SCL = 1; //Pull SCL high
delay_us(1);
SDA = 0; //Now Pull SDA LOW, to generate the Start Condition
delay_us(1);
SCL = 0; //Finally Clear the SCL to complete the cycle
void I2C_Stop(void)
delay_us(1);
SDA = 0; // Pull SDA low
delay_us(1);
SCL = 1; // Pull SCL High
delay_us(1);
SDA = 1; // Now Pull SDA High, to generate the Stop Condition
void I2C_Ack()
SDA = 0; //Pull SDA low to indicate Positive ACK
I2C_Clock(); //Generate the Clock
SDA = 1; // Pull SDA back to High(IDLE state)
void I2C_NoAck()
SDA = 1; //Pull SDA high to indicate Negative/NO ACK
I2C_Clock(); // Generate the Clock
SCL = 1; // Set SCL */
unsigned char i;
for(i=0;i<8;i++) // loop 8 times to send 1-byte of data
SDA = dat & 0x80; // Send Bit by Bit on SDA line
I2C_Clock(); // Generate Clock at SCL
dat = dat<<1;
SDA = 1; // Set SDA at last
unsigned char I2C_Read(void)
unsigned char i, dat=0x00;
SDA=1; //Make SDA as I/P
for(i=0;i<8;i++) // loop 8times to read 1-byte of data
delay_us(1);
delay_us(1);
dat = dat<<1; //dat is Shifted each time and
dat = dat | SDA; //ORed with the received bit to pack into byte
SCL = 0; // Clear SCL to complete the Clock
return dat; // Finally return the received Byte*
while(ms_count!=0)
delay_us(112); //delay_us is called to generate 1ms delay
ms_count--;
while(us_count!=0)
us_count--;
void I2C_Clock(void)
delay_us(1);
SCL = 1; // Wait for Some time and Pull the SCL line High
delay_us(1); // Wait for Some time
SCL = 0; // Pull back the SCL line low to Generate a clock pulse
