Results 1 to 8 of 8
    Advanced Member level 2
    Points: 3,793, Level: 14
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    613
    3,793
    14
    Shunt in DC ammeter circuit
    I have DC ammeter and shunt for sending current.
    Shunt is 30A@60mA and ammeter also have same rating @24VDC supply.
    But I connected 24VDC line from 2 series batteries with shunt 1st main terminal and load connected to shunt 2nd main terminal.And Ammeter connected with 2 small screws in shunt but when I energised power ammeter was burned and on-off switch for ammeter also burnt.
    I tested negative terminal of ammeter and most left terminal was showing continuity.
    Please try to understand.
    IMRAN
    Advanced Member level 3
    Points: 5,789, Level: 18
    Feb 2014
    824
    5,789
    18
    Re: Shunt in DC ammeter circuit
    I assume you mean 30A->60mV not mA. Shunts convert current to voltage.
    Use a volt-meter to measure the shunt.
    Points: 5,164, Level: 17
    ZASto's Avatar
    Jan 2008
    Messy Corner, 44°47'31.56"N, 20°28'9.16"E
    617
    5,164
    17
    Did you connect it this way?
    Green rectangle is LOAD,
    Make no mistake between my personality and my attitude.
    My personality is who I am.
    My attitude depends on who you are.
    Feb 2014
    824
    5,789
    18
    Unfortunately I don't know that the 'digital panel meter' does exactly.
    The marking on it for 30A/60mV indicate it may be configured to scale the signal for your shunt but if that's true you probably wouldn't have blown it.
    One thing to test: Before you connect a black box to the shunt measure the R of the two pins you're about to connect. They should be high R. If they're a short then current will bypass your shunt and flow into the back box, probably blowing it (unless it's a 30A meter in which case you don't need a shunt at all).
    Full Member level 6
    Points: 2,003, Level: 10
    Jan 2019
    373
    2,003
    10
    Quote Originally Posted by imranahmed View Post
    As asdf44 said, a voltmeter goes across the small terminals of the shunt.
    Read the voltage and calculate the current using the resistance of the shunt.
    Voltmeters have a very high input impedance so they do not carry any current, compared to whatever you're measuring
    When you connected the ammeter across the small terminals of the shunt,
    you connected a low impedance across the shunt, maybe less than the shunt,
    the current went through the ammeter, not the shunt
    since it was more current than the meter was designed for, it burned up.
    Points: 14,929, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,480
    14,929
    29
    Also, put a small value fuse, 1or 2 amps.
    My batteries are recharged by "Helpful Post" ratings.
  7. #7
    Points: 77,645, Level: 67
    Apr 2014
    15,729
    77,645
    67
    From the explanation it seems you connected the load on the terminals of the voltmeter....and not directly to the shunt.
    This is not the same since the wires between shunt and voltmeter have resistance that causes additional voltage drop and thus measurement errors.
    In worst case the resistance is much higher than the shunt resistance ( 60mV / 30A= 0.002 Ohms) causing too high voltage at the voltmeter inputs destroying the voltmeter.
    Thus the correct wiring is shown in post#3 ... with galvanically isolated power supply.
  8. #8
    imranahmed's Avatar
    Dec 2011
    Karachi,Pakistan
    613
    3,793
    14
    Sorry yes 30A@60mV
    IMRAN
