Results 1 to 11 of 11
    Points: 96, Level: 1
    Jun 2019
    7
    96
    Operating current in Gate Drivers
    I am understanding the datasheet parameters of LM5102. I am not understanding how is operating current measured (average / RMS current ) conditions is given as f=500khz in electrical characteristics
    Can any one share some insights on these?
    Datasheet: http://www.ti.com/lit/gpn/lm5102
    Points: 77,803, Level: 68
    Apr 2014
    15,766
    77,803
    68
    Re: Operating current in Gate Drivers
    Usually it makes not much sense to measure the current in a DC path as RMS.
    Thus I'm rather sure it is "average current".
    RMS is useful when you want to calculate power dissipation of any resistive load...where the voltage across the resistor directly is proportional to the current ... and thus the power is proportiona to squared current. P = I^2 × R.
    But there you rather want to calculate the power supply. And here P is proportional to I, because Voltage is constant. P = V × I.
    Jun 2019
    7
    96
    I have measured operating current at VDD referring application circuit in datasheet. (With condition f=500khz) Whenever there is raising input pulse I observe a current spike at VDD and during falling.
    May I know the formula for calculating the average current here and is it dependent on duty cycle?
    Points: 260,228, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,443
    260,228
    100
    With sufficient bypassing, you don't see current spikes in the Vdd supply. At the end of the day, you have to supply 2*Fswitch*Qg,total + LM5102 quiescent current on average.
    Qg,total can be found in MOSFET data sheet.
    Apr 2014
    15,766
    77,803
    68
    Yes. Generally you need to decouple (stabilize for current spikes) power supply.
    It's a good idea to place a fast ceramics capacitir at each supply pin of each IC....with low impedance connection to the GND plane.
    It should be common knowledge, but here it is additionally mentioned in the datasheet:
    Section:
    5 Pin Configuration and Functions
    --> Locally decouple to VSS using low ESR/ESL capacitor, located as close to IC as possible.
    Ah, yes, a GND plane should be mandatory for high speed switching (high dV/dt) high current applications.
    Jun 2019
    7
    96
    @FvM 2*Fswitch*Qg,total + LM5102 quiescent current gives - 2*500KHz*43nC(assume)+0.4mA this gives huge value...
    https://imgur.com/a/Lhe7gDc
    This is the current behavior which i obtain at VDD when input is 500KHz at low side even after i use capacitor at VDD and GND
  7. #7
    Jun 2019
    7
    96
    http://www.ti.com/lit/ds/symlink/lm5102.pdf
    This gives IDD vs Frequency plot at page no:7 for different Load Capacitor (CL)
    How is this plot (Figure no:1) measured/Test Setup on EVM Board (Characterized) and Design Simulation Plot ?
  8. #8
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,443
    260,228
    100
    Not sure what's unclear with figure #1? They are measuring average supply current with fixed capacitors in place of the nonlinear gate capacitance.
  9. #9
    Jun 2019
    7
    96
    How is average supply current measured here test case/formula?
  10. #10
    Apr 2014
    15,766
    77,803
    68
    Simply a capacitor is used for averaging.
  11. #11
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,443
    260,228
    100
    Side remark, a bypass capacitor doesn't change the peak current in an ideal supply voltage source without series filter elements, as probably used in your Ltspice simulation. But that's a pure simulation problem. You can easily measure average current in Ltspice, even without using a capacitor.
