Results 1 to 4 of 4
    Full Member level 1
    Points: 1,177, Level: 7
    Dec 2015
    100
    1,177
    7
    How to add the outputs of a different voltage double ciruits
    hello everyone,
    can you please help me to add the outputs of two voltage doubler circuits shown in the following figure.
    Points: 54,054, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    13,176
    54,054
    56
    Re: How to add the outputs of a different voltage double ciruits
    Rework one circuit so it outputs negative polarity. Connect your load across the two outputs. This method works if the two ground icons represent a single ground.
    Or, the output stages can be connected similar to two batteries in series. This method works if the two circuits have separate grounds.
    Points: 81,795, Level: 69
    Apr 2014
    16,607
    81,795
    69
    Omit the upper GND (symbol).
    Connect the lower end of R1 with the upper end of R1.
    Full Member level 1
    Dec 2015
    100
    1,177
    7
    Thank you sir, it worked out. can you please explain further on removing upper GND (symbol)...
