Results 1 to 3 of 3
    Newbie level 1
    Points: 131, Level: 1
    Jun 2019
    Erina NSW
    7
    131
    [moved] How to fix Windows 10 Error? (copying files from network drive)
    When I was trying to copy a file off a networked drive I get the following error: Error 0x80070057: The parameter is incorrect.
    This is the third time this has occurred. The first time I was trying to copy 6 files and 3 of them were copied correctly and the other was not. I am really confused what to do.
    If anybody knows the solution .
    Please Help Me!!
    Advanced Member level 2
    Points: 3,827, Level: 14
    May 2012
    510
    3,827
    14
    Re: [moved] How to fix Windows 10 Error? (copying files from network drive)
    Quote Originally Posted by victorjohn9211 View Post
    Please Help Me!!
    This error is caused by a corrupt file system either on the networked drive or on the system drive; you should do a system file check on both drives.
    Another possibility is that you are getting transfer errors on your network due to faulty cables, network adapters etc.
    Junior Member level 1
    Points: 95, Level: 1
    Nov 2019
    London
    15
    95
    There are many methods to solve this problem. The first method formats the disk, change the permissions of the folder, extend the Partition and remove write protection of the disk where you are trying to copy your data.
