pancho_hideboo
- Joined
- Oct 21, 2006
- Messages
- 2,847
- Helped
- 767
- Reputation
- 1,536
- Reaction score
- 733
- Trophy points
- 1,393
- Location
- Real Homeless
- Activity points
- 17,490
Calculation method of S-parameters is different between Cadence Spectre and Keysight ADSsim.
Cadence Spectre evaluates Y-parameters first internally.
Then it converts Y-parameters to S-parameters using reference impedance values.
Some simulator has option to choose Y or Z parameters.
On the other hand, Keysigh ADSsim does not use Y or Z parameters to calculate S-parameters.
Keysigh ADSsim calculate S-parameters directly by power wave formulation.
Power wave is defined by voltage, current an reference impedance.
Assume 2-port DUT where Y-parameters don't exist.
For example, shunt element.
Cadence Spectre can not give S-parameters.
Keysigh ADSsim can give S-parameters.
