Results 1 to 3 of 3
14th July 2019, 14:38 #1
- Join Date
- Jun 2019
- Posts
- 6
- Helped
- 0 / 0
- Points
- 76
- Level
- 1
How i can applied a lumped port on coaxial cable at HFSS?
i designed an array of patch antenna with coaxial fed, and defined it as wave port, but i need put it in a radiation box so i need defined is as lumped port , how i can do that ? i'm not perfect in hfss program can any body help me please ?
Advertisement
17th July 2019, 16:11 #2
- Join Date
- Jun 2012
- Location
- Edmonton, Canada
- Posts
- 1,059
- Helped
- 302 / 302
- Points
- 6,895
- Level
- 19
Re: How i can applied a lumped port on coaxial cable at HFSS?
Hi hanadi_alsalti,
Usually what I do in such cases is integrate the lumped port into the ground plane. Subtract a hole out of the ground plane at your feed location, and put a circular sheet there which your lumped port is assigned to. Extend a conductor up through the dielectric to model the pin, and the outer edge of the port should be the ground plane.
Good Luck!
Advertisement
20th November 2019, 00:26 #3
- Join Date
- Dec 2007
- Posts
- 187
- Helped
- 38 / 38
- Points
- 3,265
- Level
- 13
Could you clarify where the circular sheet (to which the lumped port is assigned) is placed with respect to the patch-antenna structure?
Wave port can also be used in a radiation box. You just need to add a PEC port cap to it.
Please login
