Page 1 of 2 1 2 LastLast
Results 1 to 20 of 25
    Points: 1,883, Level: 10
    SparkyChem's Avatar
    Apr 2010
    Lima, Peru
    47
    1,883
    10
    Does it exist an AC to AC converter in small package for converting 220v to 110v?
    Hello. I have an appliance that id like to install on the wall on my bedroom. Its a broan exhaust fan. The unit only operates using 110v and my system provides 220v. I have been looking for ways to solve my problem but the suggestions do not apply to my case. These include.
    Changing the double pole 220v to a 110v single pole breaker in the panel. I cant do that because this appartment has a simple wiring and there are not two hot wires and a neutral and ground. Just one hot and one neutral.
    Trying to use an adapter or converter. This solution does not apply to me because the intended appliance doesnt come with a plug and the connection and wiring must be all hidden in the electrical wall outlet box.
    Trying to use a transformer. The same as above. The ones i could find are bulkier and cannot be installed on the outlet box.
    Trying to find a din rail ac transformer and installing it on the electrical pannel and enabling my bedroom to have 110v outlets and current. I triend to find such but i couldnt find any. Looked on siemens. GE. Panasonic catalogs but the only ac transformers they have are for low voltages around 24v.
    Trying to look for a fan which does operate on 220v instead of 110v. Well why would i be posting this question if i had given up? I just cant find an exhaust of 220v with the thickness and characteristics of the unit i intend to install. It must be a broan model.
    The other option was. Does it exist a circuit or an AC to AC chip that is small enough to convert 220v to 110v and provide 5amps? It doesnt need to be that small but as long it could fit in an empty outlet box which i happen to have available, that would be enough.
    Can somebody help me please?
    Points: 260,279, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,460
    260,279
    100
    Re: Does it exist an AC to AC converter in small package for converting 220v to 110v?
    A 1000VA 220 to 110 auto transformer is by far the cheapest solution. An electronic inverter can perform the job in principle, but not much smaller and more expensive.
    Did you consider to get a 220V exhaust fan?
    Points: 6,247, Level: 18
    kripacharya's Avatar
    Dec 2012
    New Delhi
    1,209
    6,247
    18
    110Vac at 5 amps means 550 watts or 0.55Kw, which seems excessively high for a room exhaust. Are you sure about the 5 amps requirement ? If on cross-checking you find it's a lower amps/ watts then maybe you can find a suitably small transformer.
    Points: 11,199, Level: 25
    Aug 2015
    1,822
    11,199
    25
    an auto - Tx is half the weight approx as you likely don't need isolation - if you get one on a toroid and heatsink the two sides - this will work and be in the order of 100x100x100mm... 60Hz I presume ...
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,460
    260,279
    100
    Moderators have deleted a number of posts from this thread which didn't contribute to solve the original question.
    Dec 2012
    New Delhi
    1,209
    6,247
    18
    thank you. It was needed.
    Surely OP will be happy to get details of this "auto-tx". I am sure the OP will be very thankful.
    Which toroid core type are you recommending ? What size/ specifications ? What source can he use to obtain the same ? In Peru ? How many turns of wire are required ? What gauge of wire ? Any other tips and hints ? Why is this heatsink required ? What size ? What material ? Will it require forced cooling ?
    10cm x 10cm x 10cm is quite large. Can you not get it smaller than that ? Does this mean that toroid is >= 8cm in diameter ???
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,460
    260,279
    100
    Toroid transformer is an option if you want a smaller solution, the OP might consider it or refer to a classical EI core design. It's also a good question if the load is actually 550 VA (not 1000VA as previously written). No need to elaborate design details before the requirements have been clarified.
  8. #8
    Aug 2015
    1,822
    11,199
    25
  9. #9
    Member level 3
    Points: 2,053, Level: 10
    Dec 2009
    USA
    54
    2,053
    10
    What if you installed a wall mounted electronic 230 Volt Variable Speed Fan Controller inside the J-box?
    And then permanently set the output to 50% Power?
    Something like this ...
    SPEED_CONTROLLER
    In this model, I do not like that "OFF" goes directly to "HIGH", instead of "OFF" to "LOW".
    Does the fan have a built-in On/Off switch?
    At some low setting of the fan speed controller, the 115 Volt fan should be happy ( ie motor is not too hot )
    Verify that the speed controller that you purchase, is compatible with the TYPE of motor inside the fan.
  10. #10
    Dec 2012
    New Delhi
    1,209
    6,247
    18
    Speed controller as suggested by Summitville typically work by varying the firing angle of a Thyristor. While this provides reduced RMS voltage, it is quite stressful on the motors. Peak voltage of 220x1.414 will still appear on the output, and the sharp switch-on/off often cause fan motors to emit a buzzing sound.
  11. #11
    Member level 3
    Dec 2009
    USA
    54
    2,053
    10
    If you know, then tell us exactly what percentage of the normal-life will be lost be using a Solid State Speed controller set to 50% power?
  12. #12
    Points: 52,947, Level: 56
    Apr 2011
    Minneapolis, Minnesota, USA
    12,950
    52,947
    56
    I've seen advice telling to derate (reduce) power to an inductive load rated for 60 Hz, when you run it at 50 Hz. The reason is because an inductor admits greater current at the slower frequency. The risk is overheating and burning.
    I'm pretty sure the risk is reduced when the windings contain some amount of ohmic resistance (as is probably the case in your fan).
    It should be okay if speed is kept low enough so motor temperature doesn't get too hot.
    This raises the question 'What is too hot?'. I guess it's if, after several minutes of running, the housing is too hot to hold your fingers on the housing.
  13. #13
    Member level 3
    Dec 2009
    USA
    54
    2,053
    10
    Quote Originally Posted by kripacharya View Post
    No, the turn-on phase angle, for equivalent 120 V rms, will be small enough that 220x1.414 will never be applied to the motor.
  14. #14
    Dec 2012
    New Delhi
    1,209
    6,247
    18
    Quote Originally Posted by summitville View Post
    Interesting observation. Could you share your calculation methods please ?
  15. #15
    Dec 2012
    New Delhi
    1,209
    6,247
    18
    My intuition says that to achieve half the Vrms, we should have a phase angle close to 90deg. Which means the peak will at least be close to 220x1.414.
  16. #16
    Points: 29,644, Level: 41
    andre_teprom's Avatar
    Nov 2006
    Brazil
    8,863
    29,644
    41
    Blog Entries
    9
    The maximum peak voltage dimmed from 220vac equivalent to the peak of 110vac should be considered regardless of the rms voltage delivered to the fan.
    The half voltage is obtained with a firing angle of exactly -30° (=arcsin(½)), at least in theory.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
  17. #17
    Dec 2012
    New Delhi
    1,209
    6,247
    18
    That makes sense in so far as peak voltage is not violated. But won't this firing angle result in lower Vrms, and hence lower fan speed from what is expected? That's the point being made here. If OP is OK with that, then good.
    Only thing left to consider is the vibrations caused due to fast transients every half cycle.
  18. #18
    Nov 2006
    Brazil
    8,863
    29,644
    41
    Blog Entries
    9
    No, this was not the point, but rather to advice OP about the correct value of the absolute maximum firing angle to be adopted in the design of the control circuit, just that.
    BTW, some fans have internal electronic circuitry, so what matters for one device could not matter for another one, therefore there is not an optimal approach to solve this problem unless having more details on the fan to be dimmed.
  19. #19
    Dec 2012
    New Delhi
    1,209
    6,247
    18
    OP just wants a pick and fit solution. He's not looking to design or make anything. Referred Broan fans are most probably shaded pole induction motors without any additional electronics.
    Best suggestion so far is toroidal autotransformer. But without detailed design information the suggestion is useless.
  20. #20
    Aug 2015
    1,822
    11,199
    25
    Conduction angle is in fact about 65 degrees i.e. the first, or last 65 degrees of each half cycle, if you want 110V rms from 230Vrms
Name:	SCR firing.JPG
ID:	154387 per the above ...
