Results 1 to 4 of 4
    Newbie level 2
    Points: 191, Level: 2
    Jun 2019
    191
    Do I need footprint if I will just simulate in protues?
    I want to create nrf24l01 module library in proteus. And I was asking If I will need nrf24l01 chip's footprint?
    I will connect it to arduino to do some simulation. I don't need a pcb layout design.
    Full Member level 5
    Points: 2,832, Level: 12
    Oct 2012
    264
    2,832
    12
    Re: Do I need footprint if I will just simulate in protues?
    The footprint is only used for the PCB. It's not required for design layout or simulation.
    Newbie level 1
    Points: 15, Level: 1
    Jun 2019
    Indore
    15
    The impression is utilized for the PCB. It's not required for structure design or reproduction.
    I have been completing a reasonable piece of PCB configuration work recently, and I constantly used to utilize Proteus for schematic illustration, now and again mimicking and PCB plan.
    I had a prerequisite to enable different clients to see the schematic in crude arrangement and Gerber design, so I normally recommended GCPrevue under Windows, yet then I had an issue with the crude configuration, as Proteus seems to be, obviously, a costly authorized application, so I began utilizing Eagle 6, had a frenzy about a CADCAM mistake then 6.1 turned out and all was cushy once more, and I truly loved Eagle, wasn't as "simple" to use as Proteus yet once you get back in to the rudiments and I read the instructional exercise and observed a few recordings it was genuinely straight forward, I haven't endeavored to make a section yet.
    What truly astonished me was the number of impressions accessible for Eagle, Proteus has a decent determination however Eagle, WOW!
    So my inquiry to every one of you veteran PCB fashioners is:
    Had you the decision which bundle would you support between Proteus or Eagle and why? The main clear thing going for Eagle is there is a free form! I tried Easy-PC however returned to Eagle.
    Besides on the off chance that you are aware of some other PCB configuration bundle that is free (but restricted, for example, Eagle 6 in pins and segments and board sizes and so on), or not unreasonably costly (for trialing), however has, for example, huge and broad library/network (for parts/impressions) as Eagle I might want to hear what your recommendations/contemplations are!
    Advanced Member level 2
    Points: 5,541, Level: 17
    ZASto's Avatar
    Jan 2008
    Messy Corner, 44°47'31.56"N, 20°28'9.16"E
    679
    5,541
    17
    Have you tried KiCAD?
    Free, multiplatform, quite capable for production work.
    Make no mistake between my personality and my attitude.
    My personality is who I am.
    My attitude depends on who you are.
