Results 1 to 12 of 12
    Full Member level 4
    Points: 1,088, Level: 7
    May 2019
    Roskilde, Denmark
    235
    1,088
    7
    LM2575 variable 7A power supply
    Hi Friends.
    I want to increase the current of a LM2575 and make a adjustable 7A/30V power supply. I want to keep the LM2575' current sense feature so I came up with this design which works sort of OK in LTspice, it splits the current in a 1:10 ratio i.e. 1 part through the LM2575 and 10 parts through Q2.
    The problem is I can not figure out how to reduce the current sense resistor, I would like to use e.g. 0.1 ohm as current sense and not 3.3 ohm as it is now.
    Points: 24,498, Level: 38
    barry's Avatar
    Mar 2005
    California, USA
    4,704
    24,498
    38
    Re: LM2575 variable 7A power supply
    your schematic makes no sense. I have no idea how you're simulating this.
    Full Member level 4
    May 2019
    Roskilde, Denmark
    235
    1,088
    7
    Quote Originally Posted by barry View Post
    Hi barry. Sorry about that. The LM2575 is just there for illustrative purposes and give context, you can disregard it. What I'm simulating is this:
Name:	Screenshot from 2019-06-25 22-03-37.png
    The total current that goes through LOAD is 7A, so I want 6A through R4 and 1A through R5, which it does now - but the SENSE resistor is too high.
    barry's Avatar
    Mar 2005
    California, USA
    4,704
    24,498
    38
    Sorry, that still doesn't make any sense to me. Here's a thought: why don't you simulate your ACTUAL CIRCUIT?
    Points: 15,106, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,508
    15,106
    29
    The LM2575 is a switchmode regulator.... How can you predict that your simplistic transistor drive will dynamically share the current correctly, even if statically it "appears" to do so?
    My batteries are recharged by "Helpful Post" ratings.
    Points: 261,960, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,786
    261,960
    100
    Restart your design, try a recent switch mode controller with MOSFET power stage.
  7. #7
    Full Member level 4
    May 2019
    Roskilde, Denmark
    235
    1,088
    7
    Yes that's a great idea, but a spice model for LM2575 is hard to come by if it exist.
    Quote Originally Posted by schmitt trigger View Post
    The correct answer is: I can't predict anything, that's why I'm asking more experienced people. I will interpret your question as an indicator that it will likely not or will be too complex, so I will discard the idea.
    Yes, that's what I tried yesterday, I'm sure they exist but I simply couldn't find a simple controller (as the LM2575) with external power stage among the thousands there is to choose from e.g. Arrow in 96 pin PGA or whatever. So I tried to solve the problem when I instead should have asked if anyone can recommend a suitable controller to me.
  8. #8
    barry's Avatar
    Mar 2005
    California, USA
    4,704
    24,498
    38
    Try this:
    1) Search (google/bing..)for LM2575 spice model
    2) PRESTO!
    Or:
    1) Go to TI website
    2) Click on Products/Power Management/Find a Part
    3) Enter your parameters
    4) VOILA! 15 parts that will do what you want
  9. #9
    Full Member level 4
    May 2019
    Roskilde, Denmark
    235
    1,088
    7
    Try this:
    2) PRESTO!
    Or:
    1) Go to TI website
    Hi barry
    Thank you for your kind proposals.
    On the LM2575, that's a lesson learned for me not to give up, I saw this post https://www.edaboard.com/showthread....75+spice+model and I gave up searching before I began.
    On the TI website. Thank you once again, but I figured out how to do it on the arrow.com website, you just have to sort by output current, and those with highest output are usually the ones with external power stage.
    LT1339 https://www.analog.com/media/en/tech...ts/1339fas.pdf - I like this one, but it's DIP so I could be in doubt if this is considered a modern chip?
    LT1076 https://www.analog.com/media/en/tech...ts/1074fds.pdf - I also like this one but what I don't get is why it is limited to 2.6A when the monolithic LM1074 can do 5A, wouldn't it be expected it was the other way around?
    And this one LT3800 https://www.analog.com/media/en/tech...ets/3800fc.pdf
    And Ha Ha!
Name:	Screenshot from 2019-06-27 12-40-01.png
  10. #10
    barry's Avatar
    Mar 2005
    California, USA
    4,704
    24,498
    38
    The LT1339 also comes in an SMT package. You can always check with the manufacturer if you're concerned about end-of-life.
    The LT1076 and LT1074 have different output structures.
  11. #11
    Full Member level 4
    May 2019
    Roskilde, Denmark
    235
    1,088
    7
    Hi barry
    I'm more concerned that nobody would here be interested if I use an antiquated part.
    By monolithic I mean that the LM1074 has on-chip output FET's and can output 5A, whereas the LM1076 you bring your own FET's but the output is only 2.6A, usually it's the other way around monolithic chips are limited because you can't change whats on the chip - therefore I'm puzzled.
    I found this LT1339 reference design here and I'm wondering if it's possible to use an instrumentation amplifier across Rsense and feed the output of the amplifier into SENSE+ and SENSE- so you can get variable current limiting?
Name:	Screenshot from 2019-06-27 23-25-19.png
  12. #12
    Points: 79,089, Level: 68
    Apr 2014
    16,058
    79,089
    68
    LT1076 also has internal power switch....
