Page 1 of 5 1 2 3 ... LastLast
Results 1 to 20 of 99
    Full Member level 4
    Points: 981, Level: 7
    May 2019
    Roskilde, Denmark
    220
    981
    7
    Differential probe build
    Hi Friends
    I need a differential probe, something simple and rugged that is known to work and has minimum 100MHz bandwidth. I like this one https://www.eevblog.com/forum/projec...rential-probe/
    However I'm a bit worried if I can make the PCB layout, because it looks like it was made by a person that knows something about RF, which I don't.
    So the question is what should I take into consideration when making the layout?
    Points: 259,231, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,261
    259,231
    100
    Re: Differential probe build
    Differential probe is a rather general topic. Beside bandwidth, you want to specify input impedance, common mode range and common rejection ratio before you start any actual design work.
    The original design posted in the blog would be useless for most differential probe applications that I know. Either you have a rather special application in mind, or you don't yet realize the limitations of the design.
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    The design is basically the AD8129 and I just skimmed over the specs which seemed reasonable to me.
    High speed
    AD8130: 270 MHz, 1090 V/μs @ G = +1
    AD8129: 200 MHz, 1060 V/μs @ G = +10
    High CMRR
    94 dB min, dc to 100 kHz
    80 dB min @ 2 MHz
    70 dB @ 10 MHz High
    input impedance: 1 MΩ differential Input
    common-mode range ±10.5 V
    Low noise
    AD8130: 12.5 nV/√Hz
    AD8129: 4.5 nV/√Hz
    Low distortion, 1 V p-p @ 5 MHz
    AD8130, −79 dBc worst harmonic @ 5 MHz
    AD8129, −74 dBc worst harmonic @ 5 MHz
    And the problem is that I need four of those probes in a jiffy and I would rather not do additional design work, because I have some other pending tasks that I would like to finish before I leave and that requires differential probes. It would be nice if there were time to deep dive into the subject as I find it interesting and educational, but as you say it's a rather general topic so there must exist working designs, this is also a candidate https://blog.weinigel.se/2016/02/26/...ial-probe.html
    I think it is a bit of both, but mostly the latter.
    Could you please exemplify it's uselessness?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,261
    259,231
    100
    O.K., if you can live with AD8130 common range, this is surely an option. I have used it in a number of design, particularly high MHz current sense. +/- 10V is only achieved with high supply voltage, of course. AD8129 has very unpleasant supply current with input overload, you should consider it if overload can happen in your application.
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    I guess I can, I will be using a resistive divider for voltages higher than that. And i think that I require consistent repeatable measurement results over calibrated and exact.
    I will just have to be cautious not to overload the input.
    But what about the PCB layout, any caveats I should be aware of?
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    Here is my first version of the probe, any objections to my design?
    I'm uncertain about at least two things
    1. Will the AD8130 clip the input signal with +/- 9V supply? Personally I don't think so.
    2. Since I'm using NiCd batteries I connected the charge USB plug directly to the battery, and I figured if I use a phone charger then there will probably not be any smoke even though there is no charge control.
  7. #7
    Advanced Member level 3
    Points: 5,544, Level: 17
    Feb 2014
    790
    5,544
    17
    First, since your probe ground is basically tied directly to U1 (only 470R) your common mode voltage is limited to the 9V supply rails. Is that acceptable? I expect differential probes to have common mode ratings equal or greater to their differential ratings.
    And I'd like to see your AD8130 input pins have common mode clamps in addition to your differential clamps (zener type or diodes to the rails).
    I wonder if you need to short scope ground to USB ground. Seems you could break that direct connection (perhaps clamp them to each other for protection) and reference your amplifier output to scope ground for some additional ground common mode rejection.
    An alternative scheme could use a 5V to +/-9V isolated DC-DC instead of your charge pump.
    Finally I'll recommend having linear regulated power. This chip has charge pumps and regulators.
    https://www.analog.com/en/products/ltc3265.html
  8. #8
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,261
    259,231
    100
    Doesn't work this way, a double pole switch is needed. Reconsider!
  9. #9
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    Quote Originally Posted by asdf44 View Post
    I'm sorry but I don't understand how U1 would ever experience common mode voltages on it's input, wouldn't that require that the scope gnd is connected to circuit gnd somehow?
    The 470R's are just to limit current when the 5V zeners break down.
    AD8130 has max 5V differential voltage, and starts clipping at 5.6V
    What a splendid idea, thanks.
    LTC3265 is $10 and the MAX865 is $3, is it worth the 7 bucks? But I agree the LTC3265 is probably less noisier with that post-LDO.
    Duh... silly me, thanks.
  10. #10
    Feb 2014
    790
    5,544
    17
    Your circuit is sending the "Scope Probe" ground (BNC pin 2) directly to U2 (through 470ohm). If your scope probe ground is NOT referenced to U2's ground then you have big problems. And having different grounds is the point of a differential probe...
    $7 isn't bad considering the cost and space of discrete linear regulators. If you don't add linear regulators at least add some additional filtering after the capacitive switcher and try to keep that in its own area of the board.
  11. #11
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    Yes indeed.
    Yes but it's still a differential input signal, so I don't quite understand your point here?
    If I connect "scope probe ground" to U2's ground which is connected to scope ground, then I believe the probe becomes single-ended again and defeats the whole purpose of a differential to single-ended conversion?
    You are right and I was just about to change the design when I saw min supply voltage is 4.5V, and with 4.5V batteries it does not leave much headroom, whereas the MAX865 in min 1.6V.
  12. #12
    Feb 2014
    790
    5,544
    17
    Again consider a real scenario:
    1) The ground symbol on your schematic is connected to earth through the oscilloscope -> Call it 0V
    2) You connect your "Scope probe ground" to something that's 50V
    3) Result: R6 and/or U2 blows up.
    Point being you need to have high impedance dividers on both inputs to your amplifier since either input can be at a high voltage in relation to your amplifier's ground.
  13. #13
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    Yes I see that scenario easily happening to someone that is not considerate. But that requires that the scope is earthed (as in the planet earth) and that "something" is earthed too. Obviously if you are careless you can always blow your equipment, or worse - incorrect measurement results. For that purpose I have adapted the old adage "measure twice, cut once" to electronics: "Think twice, measure once".
    The AD8130 is U1 btw.
  14. #14
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    Moving along with this suggestion I found this document Designing Second Stage Output Filters for Switching Power Supplies, and now I'm wondering where I get the value for the angular velocity (lower case omega) from, in equations 3,4, and 5?
Name:	Screenshot from 2019-07-04 13-39-16.png
  15. #15
    Feb 2014
    790
    5,544
    17
    Quote Originally Posted by Swend View Post
    If the 'something' isn't earthed then you don't need the differential probe. You can connect your earthed scope probe anywhere you want on an isolated circuit.
    I'm curious where you think you need a differential probe.
  16. #16
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    Yes you can connect ONE OF your earthed scope probe anywhere you want on an isolated circuit. Since I have four channels I can't connect all four probes where I wan't, because gnd/earth is interconnected on the scope. My scope is also isolated/floating, even though I still can't connect all four probes where I want because gnd/earth is interconnected on the scope. I'm currently working on a isolated circuit that in addition has 24 isolated nets, and it is impossible to measure two signals simultaneously without a diff probe?
    So what about the second stage output filter? Where/how do I get the value for the angular velocity? Or perhaps you know some easy rule-of-thumb for ballpark-ing the filter?
  17. #17
    Feb 2014
    790
    5,544
    17
    So your scope isn't earthed. It doesn't matter.
    The scope ground (and your differential probe circuit ground) is at potential A
    Circuit B is at potential B
    Circuit C is at potential C
    If A, B and C could be the same potential you could use your scope as-is right now.
    Since they're not you need a differential probe that can tolerate the common mode potential differences between A, B and C.
    But your circuit as drawn can't tolerate more than ~9V between it's ground and the circuit its measuring.
  18. #18
    Full Member level 4
    May 2019
    Roskilde, Denmark
    220
    981
    7
    Now I'm confused, A,B and C are all floating that means they have no common reference, if they have no common reference there can be no common mode potential differences between A, B and C, am I right or wrong?
    And if A, B and C could be the same potential I could NOT use my scope as-is right now if I wanted to measure three differential signals (I could perhaps measure two (with four probes) if I make the scope subtract one from the other. But my scope can't make two subtractions at once, and the result of the subtraction can not be saved.
  19. #19
    Points: 14,794, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,461
    14,794
    29
    Additionally, you must add a trim capacitor to frequency compensate your dividers, otherwise the stray capacitance will form a low-pass filter.
    My batteries are recharged by "Helpful Post" ratings.
  20. #20
    Feb 2014
    790
    5,544
    17
    I'd say the opposite: If they don't have a common reference then there is nothing preventing them from having a common mode potential difference. And if they're not galvancially isolated but you call them 'floating' that implies they do have a common mode potential difference.
    But we may be arguing over definitions. I'll go back to the problem: Your circuit can't measure a signal that has greater than ~9V between your differential scope probe ground and the oscilliscope ground. In my mind that's hardly a good differential probe and you havn't made a convincing case that this is actually ok in your application. Particularly given that you want to measure high voltages.
    I think you need to diagram the whole picture including the scope and the circuits connected too it and think through what the potentials of each node are in relation to your scope ground (which is your differential probe circuit ground too).
