Results 1 to 7 of 7
    Newbie level 3
    Points: 96, Level: 1
    Mar 2019
    96
    Every few Hours clock running fast rtc1307
    What may be the possible cause for RTC1307 Module(Purchased from Market) running fast approximately 1sec in 3hrs.
    Let me elaborate what I have done,
    My code is in xc8 and internal osc configured in 8mhz at mcu16f887.
    Display is 7segments, data being extracted from RTC1307 (MODULE) with I2C, technique Multiplexed and two button is used for time setting in h/w side. All are going correctly, but
    Once adjusting time with the actual, noticed that after (apprx) 3-4 hours 1-second running fast. Is it the problems of RTC1307 Module or others of my h/w or software.
    As per my opinion that could be only for the cause of RTC module, if so then how do i get rid of that..
    Than u.
    Points: 83,954, Level: 70
    Apr 2014
    17,075
    83,954
    70
    Re: Every few Hours clock running fast rtc1307
    What do you expect from us?
    * If you want us to validate the hardware --> you need to show us
    * If you want us to validate the software --> you need to show us
    Points: 85,296, Level: 71
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    14,038
    85,296
    71
    Do what Klaus suggests first.
    If it is just the clock running fast, the problem is the crystal (or external clock if you are using one) is too high in frequency. That could be because of the crystal itself or the track layout around it. You have to follow the design guidelines in the 1307 data sheet if you want it to be accurate.
    Points: 266,405, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    46,561
    266,405
    100
    What does running fast for 1 sec actually mean? How much is the time advancing?
    Banned
    Points: 6,361, Level: 19
    Dec 2012
    New Delhi
    1,209
    6,361
    19
    Also what would be useful to know is - what clock are you using to compare this too ? Maybe your reference clock is actually running slow by 1 second per 3 hours !! 1 sec in 3 hours implies ~ 100ppm, which is not good. But then, DS1307 is not known for great accuracy or stability. Check out this writeup.
    Points: 30,364, Level: 42
    andre_teprom's Avatar
    Nov 2006
    Brazil
    9,107
    30,364
    42
    Blog Entries
    9
    Most 32.768KHz crystals (you did not mention, but it is presumably the one you're using) have good acuracy, ranging from ±5/10ppm up to ±20ppm in the worst cases; however it is possible to find brands with poor specifications of ±50ppm and even of ±100ppm (e.g this), which apparently is the one you have been got; as you took it in the retail, you certainly do not have any reference to the model/manufacturer, and in that case the tip would be to acquire a different one from this one.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
  7. #7
    Banned
    Dec 2012
    New Delhi
    1,209
    6,361
    19
    It would seem that OP was using an inappropriate reference to check the accuracy. A common noob mistake.
