vsnarkhede13
Newbie level 2
Sir I've interface 16*2 lcd with de2i-150 board but with same working code when uploaded on DE0_nano board its not showing output. Both board have same clock frequency of 50MHz.
Here is my code:
Here is my code:
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 module lcd_test ( input clk, output reg lcd_rs, output reg lcd_rw, output reg lcd_e, output reg lcd_4, output reg lcd_5, output reg lcd_6, output reg lcd_7 ); parameter n = 27; parameter k = 17; reg [n-1:0] count=0; reg lcd_busy=1; reg lcd_stb; reg [5:0] lcd_code; reg [6:0] lcd_stuff; always @ (posedge clk) begin count <= count + 1; case (count[k+7:k+2]) 0: lcd_code <= 6'b000010; // function set 1: lcd_code <= 6'b000010; 2: lcd_code <= 6'b001100; 3: lcd_code <= 6'b000000; // display on/off control 4: lcd_code <= 6'b001100; 5: lcd_code <= 6'b000000; // display clear 6: lcd_code <= 6'b000001; 7: lcd_code <= 6'b000000; // entry mode set 8: lcd_code <= 6'b000110; 9: lcd_code <= 6'h24; // H 10: lcd_code <= 6'h28; 11: lcd_code <= 6'h26; // e 12: lcd_code <= 6'h25; 13: lcd_code <= 6'h26; // l 14: lcd_code <= 6'h2C; 15: lcd_code <= 6'h26; // l 16: lcd_code <= 6'h2C; 17: lcd_code <= 6'h26; // o 18: lcd_code <= 6'h2F; 19: lcd_code <= 6'h22; // 20: lcd_code <= 6'h20; 21: lcd_code <= 6'h25; // W 22: lcd_code <= 6'h27; 23: lcd_code <= 6'h26; // o 24: lcd_code <= 6'h2F; 25: lcd_code <= 6'h27; // r 26: lcd_code <= 6'h22; 27: lcd_code <= 6'h26; // l 28: lcd_code <= 6'h2C; 29: lcd_code <= 6'h26; // d 30: lcd_code <= 6'h24; 31: lcd_code <= 6'h22; // ! 32: lcd_code <= 6'h21; default: lcd_code <= 6'b010000; endcase if (lcd_rw) lcd_busy <= 0; lcd_stb <= ^count[k+1:k+0] & ~lcd_rw & lcd_busy; // clkrate / 2^(k+2) lcd_stuff <= {lcd_stb, lcd_code}; {lcd_e,lcd_rs,lcd_rw,lcd_7,lcd_6,lcd_5,lcd_4} <= lcd_stuff; end endmodule
